Old 09-29-2022, 12:55 PM
docric docric is offline
Default Transfuser crashing PTU 2022.9
I'm probably the only guy still using this plug-in... BUT...
... as of updating our PT rig to 2022.9 this am, anytime I launch AIR's Transfuser plug, the system crashes.
PT allows me to assign Transfuser to a track just fine.
Also, if the Transfuser track is already completed, playback works w/o problems.
When I click on the inserted plug to open it up for editing, however, PT crashes.
Tried it in multiple different sessions... same result.
Created a brand new session w/ one stereo instrument track- same result.
I use the AIRIEP3 plugs a lot in my work... the rest of their plugs are working fine.
I've reached out to InMusic/AIR & await reply, but past history tells me not to hold my breath.
Additionally, I've sent multiple crash reports to Avid this am.
System specs below... anyone else out there using this plug w/ 2022.9?
-C' ya'
Rick
MacPro 7,1; 16 core; 192 Gb RAM; Sonnet M.2 x2; OSX 12.5.1
PT 2022.7 Ult.; Eucon 2022.4.0.78
Burl MS / PT Dock/ Avid S1/2x iPad Air2/ Avid|Control
Old 09-30-2022, 01:58 AM
unkJE's Avatar
unkJE unkJE is offline
Default Re: Transfuser crashing PTU 2022.9
Originally Posted by docric View Post
...... anyone else out there using this plug w/ 2022.9?
Transfuser 2.0.7.21000 works in PT 2022.9 on Windows
- are you running this version:
Mac Installer - Transfuser_2.0.7.21000 macOS Catalina, Big Sur & Monterey Compatible (M1 Mac not supported)
https://help.pluginboutique.com/hc/e...-Download-Area
In the plug-in: (RHS of ‘air’)>Spanner>Content Location>”Choose new directory. Requires restart”
(Track>’no insert’ then re-instantiate Transfuser = all good here!)
Pro Tools 2022.10 & 12.5.1 HD - Studio One 5.5.2 Pro - Win10 64 Pro – 32 GB RAM - Lenovo W520 ThinkPad (4276-37U) & 433830U Dock – SSDs Samsung 860 Evo & 2 T5s – Digidesign Command|8 - SSL UC1 - Mbox 3 Pro - Axiom Pro 49 – Eris E 4.5 spkrs
Old 09-30-2022, 09:46 AM
Originally Posted by unkJE View Post
Transfuser 2.0.7.21000 are you running this version:
Thanks for the help, unkJE... unfortunately, that is the update I'm running (on the mac side the file is actually Transfuser_2.0.10.21000 ).
Been in contact w/ inMusic TS & it looks like this is the most recent version.
Still interested if any other mac users are using Transfuser successfully (or not) with 2022.9 ?
-C' ya'
Rick
Old 09-30-2022, 02:11 PM
nednednerb nednednerb is offline
If you never used 2022.9 in your work before, because it never existed,
I suggest you ought to consider updating to a new plug in that has more support, or for now stick with the version of PT that allows you to do your work.
Obviously running a system with the oldest piece of ______ inside the newest shiniest _______ does NOT matter compared to getting "lots of work" done, right?
Also,
You can rename in your Application folder "Pro Tools" to something like "Pro Tools.9" and then you can install the older version and work with it until the time AIR provides an update or you find a replacement. You can run both at the same time. There MIGHT be some overlap in referenced folders etc/libraries etc, but for basic testing should be good to go. Do your main work in the stable-for-you version.
___
>> me: nednednerB //
||main gig: editing audio & testing software / 2nd gig: music software tutoring //
||software: Monterey 12.5.1 | PT Studio 2022.10 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB //
||devices: Focusrite Clarett 2Pre | some AT condenser mics | SM58 | Ableton Push 2 | 32" 4k LG secondary display //
||automation: SoundFlow | Keyboard Maestro | SteerMouse //
Audiosuite plugins crashing Protools 2022.6 on MAC M1 Max paulo m Post - Surround - Video 10 10-21-2022 03:30 PM
ProTools 2022.6.0 Plug In Crashing Issues postpro Pro Tools HDX & HD Native Systems (Mac) 4 07-14-2022 02:24 PM
Pro Tools 2022.4 CRASHING upon LAUNCHING on Monterey 12.3.1 nightowls Pro Tools 7 06-10-2022 02:16 AM
