  #21
Old 09-29-2022, 09:24 PM
bobdaspit bobdaspit is offline
Default Re: Pro Tools 2022.9 "Saving ARA Data"
Same here. "Saving ARA Data" constantly interrupting workflow.
Mac Pro Trashcan
OS 10.14.6 Mojave
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
>>edit<<
Melodyne 5.3.0
was still hanging up when I had a single track w/ Melodyne enabled, but made the track inactive
>>edit<<
(ps - not my first post - ancient login credentials wouldn't work)
  #22
Old 09-29-2022, 10:43 PM
Dizzi45Z Dizzi45Z is offline
So, another session I did today didn't have the problem at all. I'm wondering if it has something to do with saving Melodyne'd clips in the playlist. I'm still exploring though.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2022.4
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.6.0
Noisebox Studios -Utah Recording Studio
  #23
Old 09-30-2022, 01:12 AM
noiseboyuk noiseboyuk is offline
Originally Posted by scottfrankfurtstudio View Post
This issue is happening for us at SFS too. Definitely related to Auto-save, which I have set to three minutes - but this is a deal breaker unfortunately as it tends to delay at the worst times...
Once again - specs?
Still not seen anyone explicitly say they’re having this problem on Windows. Prove me wrong, someone.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2021 Ultimate; W10 Pro; i7 7820X; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
  #24
Old 09-30-2022, 02:16 AM
scottfrankfurtstudio's Avatar
scottfrankfurtstudio scottfrankfurtstudio is offline
Originally Posted by noiseboyuk View Post
Once again - specs?
PT Ultimate HDX, Mac Pro, Mojave 10.14.6, 96GB Ram, 2 x 3.46Ghz Intel Xeon, Melodyne Studio
  #25
Old 09-30-2022, 02:36 AM
Thanks Scott.
I just went through the whole thread and there's no direct consistency with which version of MacOS people are on. Lots of reports of problems but one person on Mojave and someone on Monterey 12.4 reported no issues.
Someone on 12.5 suggested increasing the autosave time to 5 min seemed to eliminate the issue completely (if I understood right) but that didn't work for you right, Scott?
Only one Windows report where there was no pop up, but there was a hiccup when autosaving.
Guy Rowland
  #26
Old 09-30-2022, 08:48 AM
mkosacek mkosacek is offline
I am getting this on Windows and it is super annoying. Many times I'll use keyboard shortcut sand sometimes it "misses" them because it has started the "Saving ARA data..." even though it may not have appeared on the screen yet. It takes several seconds for this process to complete and like I said it is actually is longer than what you see on the screen and when it is in process, PT responds to nothing else and doesn't give you any error or indication that it missed that last keyboard shortcut... you just have to know.
I was checking here before I file an official bug. It definitely happens every time I hit "CTRL+S) to save -- and this is a constant part of my workflow because I have been burned by PT crashing and losing editing work enough times that I always do this. So I am not OK with a workaround to reduce the frequency of my manual saves, or the autosave either. That is just setting us up for other disasters.
edit: btw I also would get this intermittently when I just scroll the Melodyne window left/right or if I manipulate any notes in Melodyne
my Melodyne license is "assistant" but I don't think that should matter, it's the same version that PT 2022.9 installed, only the ilok license affects the features.
Pro Tools 2022.9
UAD Apollo 16 (v10.1)
Dell XPS 8940 (i5-11400)
Win10
www.studiodrumtracks.com
www.doubledogrecording.com
  #27
Old 09-30-2022, 08:52 AM
Oh that's bad news mkosacek but thanks for the report.
I took the plunge. No problems so far with this issue, but that's because I haven't really got Melodyne working at all. I get an error code when trying to edit on a stereo track (thread on that here - https://duc.avid.com/showthread.php?t=421832 ).
So far everything else working ok, so no need to roll back for me, I'll just avoid using Melodyne until this issue has been resolved.
Guy Rowland
  #28
Old 09-30-2022, 08:54 AM
I may just have to revert to using the Melodyne plugin and see if that prevents the "saving ARA data" messages from disrupting my workflow (and slowing me down to about 50% efficiency)
I submitted a case to both Avid and Celemony (Melodyne) and would highly recommend that anyone else seeing this does the same so it gets fixed before 2025.x
Pro Tools 2022.9
Win10
  #29
Old 09-30-2022, 09:01 AM
loud neighbor loud neighbor is offline
Yeah, this is too much to ignore now.
In my case:
1. Edit with ARA
2. Commit track - hide / make inactive
3. Manually remove ARA from newly committed track (ARA is enabled by default on the new track - no option to prevent this)
4. Even with no ARA tracks active in the session I'm getting "Saving ARA Data" prompts ever time I manually save and I assume whenever PT auto-saves. (changing from 1 to 5 minutes on the auto-save doesn't seem to change anything for me)
MacOS 10.15.7 Catalina
Mac Pro 2019
Melodyne Studio 5.3
  #30
Old 09-30-2022, 09:52 AM
midnightrambler midnightrambler is online now
Oh my gosh, it happens every time you press save, and, if you've been playing the track or cycling for a while, every time you stop the track as well.
Actually to be fair it kind of did this if you were running a lot of Melo plugin instances, but it just didn't bother telling you what it was doing.
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 04:43 PM
"Error, missing PACE authorization" with PT 2022.4 and iLok USB Key [FIXED 5/27] DaveGross Pro Tools 56 05-27-2022 10:05 AM
Pro Tools not importing volume with "import session data" lapieuvre Pro Tools 12 4 10-16-2015 07:02 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 02:04 PM
Pro Tools LE and "Import Session Data"? lydpik Tips & Tricks 5 09-11-2009 06:12 PM
