Hard Drive Related Problems
Hello,
I hope everyone is well. Before beginning, here are my PC Specs and Hard Drive situation As of Pro Tools, I am running Pro Tools 12.5.0 HP Omen Laptop i7 10750H 16GB RAM 1660Ti 6GB Windows 11 Home Hard Drives C: SSD with 512GB D:StoreJet 25M3 with 1TB E: SDSSDE30-2T00-G25 with 2TB I am currently working on alot of Pro Tools projects, that are all stored and ran off the E hard drive. All of a sudden, I am unable to save progress on already created projects, and even save newely created projects to the E hard drive. Pro Tools either pops up once in a few minutes stating that it cannot autobackup the session, or this error when I press CTRL + S: Could not save "" because The system cannot find the file specified. (2) e:\SESSIONS\SESSION FOLDER NAME\ghmsYYQQgqdzMBBB. This randomly named file cannot be found anywhere on my hard drive... The weirder thing is once I copy the same exact session to my D drive, it will perfectly work and I am able to save any progress on the session. I know certain people would suggest simply moving to drive D, but I am not willing to do that as its a much slower hard drive and it is not stable enough... Thank you very much to anyone who can help |
Re: Hard Drive Related Problems
Hi, and welcome to the "DUC".
Not everyday we can welcome a new member from your continent. I can't help you with your specific problem, but I can tell you that windows11 was never supported w/PT12. In fact, only the very most recent versions support w11: Pro Tools Operating System Compatibility Chart It doesn't mean that's the cause of your problem, or that it won't work. I'll leave it to my windows friends on the forum to hopefully help you out further.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Hello,
Thank you very much for the welcome. I would like to note that this problem is something completely new... I have used Pro Tools on Windows 11 for the better part of a year without any issues. It seems to be more hard drive related and not windows related, I might be wrong though. |
First I would check Workspace > Volumes and make sure the E drive still has "R" permission.
Are you running any backup software on that drive in the background?
~Will |
Personally, I would get a new hard drive, preferably an SSD, and get your sessions off that drive. If it hasn't change "R" in the Workspace, it's probably failing.
I consider any and all of my drives, even though at the moment they're fine, to be on the edge of failure. I image them nightly with Macrium Reflect, keeping a rolling 3 nights, and also image before any update/upgrade/install/uninstall.
The hard drive which seems to be problematic is an SSD..
I would not be surprised if its failing, I have already copied any significant files off of it in case of immediate failure. I hope it is simply a problem on the software side of things though |
Update:
I installed the exact same installation of Pro Tools on a fresh PC which never had any plugins etc. The hard drive worked without any trouble and without any errors...seems like its a software issue. (I did backup the hard drive for the worst case scenario) Would love to hear if there is any known fix to these kind of problems |
If your OS&PT combo is blessed by Avid, top three causes for random errors are:
- plugins - plugins - plugins WIth that said, W11 and PT12.5 are not compatible
Hello,
After a fresh wipe of Pro Tools, I have had 0 issues so far. I will do my best to upgrade as fast as I can to avoid any other issues. Thank you |
Help Hard Drive Problems | wolfman_rob | Pro Tools TDM Systems (Mac) | 5 | 12-21-2012 06:25 AM |
Bizarre hard drive failure... help!! MOTU MachFive related? | Jon_Atkinson | Pro Tools TDM Systems (Mac) | 6 | 04-01-2008 05:02 PM |
New Hard Drive. More problems | G. Klopfenstein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-10-2006 12:09 AM |
Hard Drive Problems | Purpleb | Storage Subsystems | 1 | 11-24-2005 12:17 PM |
OT Hard drive problems | JonMitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-29-2004 11:48 PM |
