Old 02-19-2012, 09:25 AM
AMcG AMcG is offline
Default Mbox Distortion
When using my Mbox mini I am hearing clipping/distortion even when working at moderate levels. It does go away if I turn the output down past 12 O'clock. If I use the built in output, then the sound is fine. So it is possible to mix by bypassing the Mbox all together, but this isn't a practical long term solution. When the problem first occurred, I could make it go away by changing the "Playback Engine" settings a couple of times. Nothing specific, but changing a few settings and relaunching Pro Tools sometimes worked, but even that doesn't do it any more. Could this just be a problem with the Mbox? (It's an mbox2, probably about 6 years old). Would it be worth trying to borrow another Mbox to test with my system?
Cheers.
MBox distortion Jaydik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-06-2005 09:37 AM
mbox distortion cosd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-23-2005 04:40 AM
MBox distortion paying customer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-22-2005 04:32 PM
Help! MBox distortion. mars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-11-2003 11:27 PM
Mbox distortion Mungrin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-07-2003 11:12 AM
