Longstanding "Bug" - AudioSuite and Muted Clips
This has existed for as long as I can remember and persists in 2022.9. Running any AudioSuite process across multiple clips where some clips are muted will process and unmute the muted clips.
An ideal fix, in my opinion, would be a checkbox in the AudioSuite plugin (or an option in Pro Tools preferences) to either Skip Muted Clips or Process Muted Clips, but with the result being that any muted clips STAY MUTED, whether or not they get processed. As it is now, on a dialog edit, I may have muted clips that are alts or for another reason, that I want to stay muted, whether I want them processed or not. On a long show, it's very time consuming to either select chunks of unmuted clips in between the muted ones, or to go back after the AudioSuite process and re-mute the clips that were previously muted.
Scott Gatteño |
Re: Longstanding "Bug" - AudioSuite and Muted Clips
Mac Pro 3,7 GHz Quad-Core Intel Xeon E5 Mac OS 10.15.7 ProTools Ultimate 2020.11 Video Slave 4.3.477 |
+1
Very good proposal. Can't stop to dream about it.
http://felixrost.de |
Good feature request. If you file it with Avid like a bug they can create an official request.
~Will |
Good point! Will do.
Scott Gatteño |
+1
Add it to the feature request section of the lounges and it will get implemented in no time.
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12 |
+1! Where do we file bugs? Sorry, probably a stupid question...
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies Last edited by huzzam; 09-30-2022 at 08:50 AM. |
+1
Manu PT Ultimate - Mac Studio M1 Max - Monterey - RME Fireface UFX II - 2x S1, 1x Dock with an iPad 7th gen - Genelec 8330 5.1 setup |
I think to officially file a bug, you have to start a support case and go through the support process, which can be a bit time consuming and frustrating if you get an entry level support person that is reading a script and insists on going through the whole turn it of and back on again, trash preferences, etc. rigmarole.
But somebody please correct me if there's a better way to directly file a bug report.
Scott Gatteño |
I can assure you there is probably no faster way than this without being involved in the company as a higher up. ONLY the higher ups can achieve calling off the devs from their ONGOING tasks. In any release cycle, they're still probably working on requests that DID get through to attention about 3-4 months ago. MacOS gives beta versions ahead of time, but that doesn't actually give the same test results as when after it lands. Hence, new PT nearly always getting qualified for a MacOS which is a couple point-updates ahead. So, even though the idea might be "great" and might be "easy" - that doesn't make the already ongoing work schedule and focus they have easier to quickly shift, pivot, and get right back to work. Since there are many, many, many users altogether, if the 5-10 or so I saw give this a "+1" ALL got on the case maker and made this THE top rated issue, it will still not be instant, is what I'm saying. AVID is in the business of providers media makers the tools to meet deadlines reliably. Mostly, when I stick to qualified versions and maintain plug-ins etc, I very rarely have the crashes and problems reported on the forum daily. They aren't very much for Zero Day Exploits and instant bug fixes. But "+1" on this forum.... NOT on the radar of devs, to be sure. I totally like the idea of "do not process muted clips, and leave muted" - Another workaround for me (less work conceivably too) would be "select only un/muted clips" to slide em quick to another track. Commands Focus enabled: "select muted" X ; V Simple solution there. Since audiosuite could conceivably be a time effect with a reverb tail going over a muted section, it gets confusing to "process a selection" AND leave a clip muted, and in place, without overlapping things maybe. That makes the options of "leave in place" a LOT more convoluted than it may have appeared when making the suggestion in the first place. All in all, thinking about it, I just want a way to select all muted or unmuted and put the exactly where I intend before doing an audiosuite. I only want to audiosuite a selection IF all clips are unmuted, now that I think of it....
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? | ZerglingPhilosophy | Getting Started | 1 | 09-02-2022 03:43 PM |
"-" toggles between notes and clips view on MIDI tracks... | tooold | Pro Tools | 0 | 01-22-2022 09:19 AM |
"-" key no longer switches MIDI track from clips to notes SOLVED (duh) | tooold | Pro Tools | 3 | 12-16-2021 08:07 AM |
Does "clearing" clips from clip list remove from disc or just project? | soundartsonline | Pro Tools 12 | 6 | 11-07-2021 06:56 PM |
Batch-Spot Multiple Clips to "Original Time Stamp"??? | jgiannis | Pro Tools 10 | 2 | 07-23-2015 11:54 AM |
