Old 04-01-2024, 06:04 AM
tonyw7 tonyw7 is offline
Default Media Composer first
I don't know if this the right place to post this question, but I am trying to install Media Composer first on my computer, and it will freeze up when trying to initialize plug-in AMPIPluginDSM.avx. I have a Mac Pro 2013, mac OS Monterey.I do have PT 2024 installed, and some of the things I seen on forums said to uninstall PT before installing Media Compose. I did that with no luck.
Any help would be appreciated
Thanks Tony
Old 04-01-2024, 08:11 PM
audiolex1 audiolex1 is offline
Default Re: Media Composer first
Thanks Tony
Check the computer specs for MC. It might need a specific CPU that is needed for Media Composer.
.avx is a specific instruction set or extension. It might be that your CPU doesn't have AVX2.
If you are on a Trashcan, you might be on an Ivy Bridge. Haswell is the AVX2 chip you would need.
I had this issue with Dolby before.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 04-02-2024, 09:59 AM
Thanks for responding
I did install MC on my mac studio M2 running Sonoma, hoping that you were correct,,same issue, freezes on trying to initialize plug-in AMPIPluginDSM.avx. According to avid this computer is compatible to run Media composer first. I don't understand why Avid would release this software when you can't even open it??
Thanks again Tony
Old 04-02-2024, 10:00 AM
tope d's Avatar
tope d tope d is offline
Thanks Tony
Hi Tony!
Are you already a member of the Avid Video Community forums? you can register at community.avid.com
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 04-02-2024, 10:19 AM
I can't log into it, tried to link my acct to it but failed,, can you tell me why this program isn't working ???
Old 04-02-2024, 10:26 AM
Ok I see what could be the problem from the link you sent me.
Thanks, tony
Old 04-02-2024, 11:28 AM
tope d's Avatar
Thanks, tony
Happy to help! You can also join the facebook group at facebook.com/groups/mediacomposerfirst
-Tope
www.topedomingo.com
Old 04-02-2024, 08:10 PM
Thanks Tope
I found the plug-in that was causing MC to crash on start-up
Opens now, but still hangs up on plug-in AMPIPluginDSM.avx for a while but eventually opens.
I will check out the FB page.
Thanks, again Tony
HTML code is On
AAF from Media Composer error, "media file's location" Diosan Post - Surround - Video 7 07-10-2018 03:10 PM
Media Composer ramson General Discussion 1 02-13-2018 06:17 AM
Media Composer AAF clips referencing incorrect section of media David McCarthy Post - Surround - Video 13 03-30-2017 12:11 AM
Media Composer 4.05 - OSX 1O.6.4 anyone? MIKEROPHONICS Post - Surround - Video 1 09-07-2010 10:45 AM
