June update - hybrid info
looks like we're getting an update this month according to this mailout from Westlake. good stuff, not sure if they've jumped the gun slightly on this announcement
https://westlakepro.com/avid-pro-too...HDX+this+Month |
Re: June update - hybrid info
Nice, I have said it before, Avid should have all Pro tools engine on native. Hybrid means all the audio engine is native but uses the hdx chips for plugins. Wich is cool.
Their next step is to eliminate voices. And I really hope they eliminate or upgrade the 32 I/O limit.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
It's probably all good. Avid published its June release back in March - https://www.avid.com/resource-center/hdx-hybrid-engine I'm looking forward to it. From the sounds of some of the chatter in the Eucon sections of the forum, it seems like there will be a pretty tasty update to EuControl too.
Pro Tools Ultimate 2022.12. OSX 13.2. Win 10. HDN. DAD DX-32R. DADman 5.3.4.2. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Sync HD. Dolby Mastering Suite 3.7.2 via RME HDSPe MADI. |
HDX allows a mix. If you've mixed with both, you'll understand the issue here (when latency isn't an issue but you want to share resources between native and dsp).
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I hope they've re-coded the entire audio engine to be more efficient and stable, soup-to-nuts, and that it's even smoother with Virtual instruments. That's all. I mean, I'd really like the MIDI stuff, new shortcuts and Sample-Rounding Error fixed, as I've been requesting. But if I'd bought that HDX card a decade ago, instead of the HD|Native card (after selling my year-old HD Accel cards to do so), maybe I'd be bouncing merrily along.
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
What happens when you engage DSP Mode on a track on a Carbon system that doesn't have input monitoring or record armed? For what it's worth, I think the same DSP plugin before native plugin trick still applies with the Hybrid engine. If you toss a DSP trim plugin before your native plugins, the native plugins won't be bypassed when the channel is record/input armed.
So I don't know about current HDX as I went from LE to HD Native to Carbon Hybrid
But as far as Carbon Hybrid operation Quote:
Then no that is not what happens with Carbon DSP Hybrid With Carbons current Hybrid implementation,,, It is a one or the other not both, on any single track In Carbon while you can have a mix of tracks in the same session some in DSP mode and some in Native mode,,,,,,,,, BUT on any single track if in DSP mode, any Native mode only plugins ( not AAX-DSP capable) will be bypassed, regardless of order, does not matter if you put a DSP trim plugin first. So to recap #1 On a track that is put into in DSP mode any Native plugins (already on the track before being put into DSP mode) will be bypassed.... And when a track is already in DSP mode you can't put a Native only plugin on it , the only plugin selections you have are DSP capable plugins #2 On a track put into in Native mode all plugins will be switched to Native mode
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Ventura 13.2.1 Enjoy the Journey.... Kev... Last edited by K Roche; 06-06-2021 at 10:19 AM. |
So what happens on an Instrument Track with a native VI on the first insert? Can that be switched to DSP mode?
Dave Marsden UK |
Here a quick off the cuff very brief summery Video I did for some guys in another forum ( don't remember If I have linked it here or not) who were asking about Carbon and DSP https://youtu.be/YFhujEU8X30
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Ventura 13.2.1 Enjoy the Journey.... Kev... Last edited by K Roche; 06-06-2021 at 11:27 AM. |
Could you explain a little more about how "DSP Mode Safe" works? If there is more to it than in the video. Thanks
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps. |
Info on the AIR Hybrid Upgrade | DonaldM | AAX Plug-ins | 8 | 05-12-2014 01:30 PM |
Smack & Hybrid not working after OS update! | KingAce | Pro Tools 10 | 7 | 02-05-2014 01:21 PM |
Hybrid update | rabs | Virtual Instruments | 1 | 06-05-2008 12:00 AM |
Hybrid Update | rabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-03-2008 02:19 PM |
Can't Install Hybrid update or Velvet | sirgant | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-01-2008 01:14 AM |
