Using plugin as channel insert PLEASE HELP
I'm new to venue. Everything makes sense and went smooth. But I can't get plugin working. Plugins on aux work just fine like revibe and etc. But every time I put something on channel insert, it just doesn't work. I made sure it's IN and active. But no luck. For example, I put Smack on snare channel, but I don't see any input metering moving on Smack. What am I forgetting here??
Re: Using plugin as channel insert PLEASE HELP
Are you driving enough level into the channel (use gain guess, it's your best friend). I typically start with a factory setting under Smack to get a ball park then adjust as needed.
Scott |
I find with Smack in particular that you need to crank the input to the plugin pretty high, at least setting it at 6 or 7 with the output at 4 or 3 to balance things out. Along with a proper gain stage to the channel in the first place you should be set.
How to insert hardware as channel insert | Lqoau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-19-2012 07:29 AM |
Multi-channel plugin default 'channel view'? | Floydio | Tips & Tricks | 1 | 11-26-2010 10:47 AM |
How to Copy Plugin Insert From a Channel to other channel | Amr Mahmoud | ICON & C|24 | 8 | 11-12-2008 04:15 PM |
channel insert | djxodus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-30-2003 01:42 PM |
Recording from an insert channel | matt vallo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-17-2002 07:38 PM |
