Digi Re-Wire plugin
I deleted it when i first brought my MBox mini because it was causing problems when trying to start up PT...
I have just discovered that i need it for something important. Help! Is there somewhere i can download it from? I have all my disks if that helps Thanks |
Re: Digi Re-Wire plugin
The "DigiReWire.dpm" plug-in is a DigiRack plug-in, automatically installed when you install Pro Tools. If it is not in your Plug-ins folder, then you would install Pro Tools LE again to install all of the DigiRack plug-ins.
Administrator Avid Pro Audio Community |
I am having the same problem. How do I delete the digi re- wire plug in? Better yet, how do you fix the problem.
Thanks. |
so I have the digi003 mixer not the rack....and this same plugin is giving me a problem when starting up protools....is the plug in compatible with the 003 mixer???? should I even have this plug in????
digi 002 fire wire problem | isaacchez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-18-2007 10:00 PM |
Digi 002 fire wire won't go to computer | ttrroopprr | General Discussion | 2 | 03-01-2006 11:41 AM |
Digi 001 and reason re-wire pc | geraldg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-05-2005 08:46 AM |
Digi 002 and Fire Wire 800 | NuBus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-12-2003 12:58 AM |
Digi Fire Wire!!! | David Fisher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-31-2002 03:51 PM |
