Old 04-11-2005, 10:12 AM
dodlum dodlum is offline
Default Renaming Regions Help
Hi there,
Do any of you know of a way, when renaming multiple regions on a single audio track (using the rename region command), to apply the new name to all selected regions without having to manually enter the new name for each of the regions....?
Is there a qualifier key or something?
Thanks
David
Old 04-11-2005, 10:19 AM
KingFish KingFish is offline
Default Re: Renaming Regions Help
I'd likely Consolodate the regions, name the new 1 region, then if you wish to re-trim the individual regions on that track, they will all carry the Name you used. with a numbe ... i.e renamed02_03.01 etc...
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 04-11-2005, 10:25 AM
Thanks for that... The reason I'm trying to rename the regions is to try a cheapsakte sound replacer kind of thing.. I need to rename the regions with exactly the same name ie. no numeric suffix, to prepare them for using replace region..
Thanks again,
David
Old 04-11-2005, 10:50 AM
Big World Big World is offline
Hi There,
In the audio menu use the "Auto Rename Selected" command. That should help you.
Doug
Old 04-11-2005, 11:10 AM
Is there a way to get auto-rename not to name regions consecutively..?
Renaming regions cosmorecording 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2011 09:49 AM
How can I stop PT from renaming regions? Frank Kruse Post - Surround - Video 17 01-14-2008 12:39 PM
Renaming Regions Sonny in London 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-30-2006 12:28 AM
PT 7 Renaming and why it doesn't rename regions Dan Pinder Pro Tools TDM Systems (Mac) 4 11-08-2005 11:16 PM
Renaming Regions WTF? NCM engineering Pro Tools TDM Systems (Mac) 2 07-14-2004 01:19 PM
