Old 02-09-2005, 10:28 AM
DrDVD DrDVD is offline
Default G4 supports higher voice count than G5 at 192?
Hi all,
Can anyone explain why Digi's compatibility page for HD Accel shows 36 voices @ 192KHz on a Dual-1.2GHz G4, but only 24 voices @ 192 on a G5? How could that be?
TIA
Old 02-09-2005, 01:02 PM
DigiTechSupt's Avatar
Default Re: G4 supports higher voice count than G5 at 192?
I believe the information you are referencing is specific to systems with an expansion chassis. With no expansion chassis, both G4 and G5 can achieve 36 voices at 192k (requires 6 SCSI drives).
Due to architectural changes in the PCI bus, the track count for 192k on a G5/expansion chassis system is only qualified up to 24 tracks (requires 64-bit chassis). If you need both a chassis and 36 tracks of 192k, a 64-bit chassis and a fast G4 is the only supported config.
regards,
Digidesign Technical Support
Avid Audio Tech Support
Support FAQ
Old 02-10-2005, 07:23 AM
Niels B Niels B is offline
Hi.
Where can I find a list with trackcount vs number of scsi-drives @ sampling rate?
Thanks, Niels
Old 02-10-2005, 01:00 PM
http://www.digidesign.com/compato/osx/hd/drives.cfm
regards,
Support FAQ
Old 02-18-2005, 10:57 AM
Is 6 the maximum number of scsi-drives you can use on a hd-system with the scsi-128 card? G4 1.42 dual? Or can you get a higher trackcount @ 192 khz with more drives?
Tanx, Niels
Old 02-19-2005, 12:09 PM
Danny Caccavo Danny Caccavo is offline
Tanx, Niels
With a G4 and 64 bit expansion chassis (or G4 internal), 36 voices are the max. More SCSI drives won't take it any higher.
Danny Caccavo
Digidesign
SATA or Firewire 800 for higher track count? BigEvil Pro Tools TDM Systems (Mac) 7 01-17-2011 01:39 AM
Higher channel count on Mixrack Roland Clarke VENUE Live Sound Systems 3 05-22-2009 12:44 AM
Higher simultaneous recording track count in 7.3 coronos Pro Tools M-Powered (Win) 1 12-14-2008 12:09 PM
8meg drive buffer=higher track count?? Nitronick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-17-2003 11:32 PM
Higher Track count for ProTools Le??? NuBus General Discussion 7 07-21-2001 11:48 AM
