¡HELP! ¿How to Create MP3 Stereo file?
Hi guys, this is my first post I Couldn`t explain my problem very well at the tittle but I will do it below
I`ve been using protools 9 at IOs since 2 months ago, so Im a noobie, I`ve download reference guides and all that stuff and I`ve learn to much with it; and I`ve realize that is as hard as I though, but I know I will make it So here is my problem: Im recordding a song with a portable reccord box and when I come home I edit andfix the audio with protools, I set almost everything, well... I already finish my proyect, i guess, but all this time I forgot the most important thing, HOW CAN I PASS MY PROYECT TO AN MP3 STEREO FILE!!??? I`ve set al the audio on diferent mono track and with the protools mixer`s paner, or balance ball, the side or balace of each instrument, but when I play it on protools it is always in mono, and the db bars of L and R moves as the same level all the time. I though that was becouse every time I imoport an audio file I set it on mono track, becouse if I chose a stereo track I can`t import a wav file if it dosen`t have the .L with the paralel .R file. So after all of this I continue, I bounce my project into a multi mono bounce(?) and it ran well, it makes me 2 mp3 files with extension .L.mp3 and other with .R.mp3, I gues that after that I should combine it as we do when we download those zip or winrar files hat came in parts and you should put the together to get 1 file. I opned a new session on protools 9, I add a new stereo Track and select the 2 files with L and R, and they open sucsesfuly, but again, when I play them on protools I still listen it on mono, but this time the db bars of L and R works independly and the wave form of L and R are diferent so I guess thats a good new . I bounce it again on Multimono and gives me again 2 mp3 files with an R and L extension. So my cuestion after all my story is... HOW CAN I MAKE A ESTEREO MP3 FILE? I`ve check the way I root my monitors and they are ok, I if open an mp3 song with protools I can Listen the stereo track, And I also check it with headphones, I put them Into the Mbox and direct to the PC and the problem its still there THANKS sorry if I get grammar mistakes, Englis is not my native lenguaje. |
Search the reference manual for bounce to disk
And you want to set it up to a stereo interleaved file And of course as u wanted it Mp3
Re: ¡HELP! ¿How to Create MP3 Stereo file?
I´m want to bouce it on a hard drive (usb) not on a CD.
I´ve already search that on the reference guide, but it dosen´t says anything aboout it, it just sayas that I can save my project on an mp3 stereo file, but it dosen´t say how to do it, I will keep looking how to do it. Thanks by replying. |
I will look it up for u - give me an hour
http://avid.force.com/pkb/articles/e...Guide/en379111
Page 1064-1071 (ENG Version) Describes it in detail...I have included the link which lets you select you prefered language.. ..............If the page numbers don't match (come on AVID - jk )
Use the selector tool to define the area you want to bounce. CTRL+ALT+B should bring up the bounce dialog box. After that its a matter of checking the right boxes.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I am not particularly fond of Avids MP3 conversion.... I use a free program called switch:
http://www.nch.com.au/switch/index.html There is a free version half way down the page on the right... I bounce out of Pro Tools at CD quality (16 bit 44.1K ) and then convert to MP3 in Switch (It has a lot more options to adjust the codec for your particular purpose, allowing you to make full sized MP3's or smaller for various streaming). This is to bounce/convert to a hard driv not a CD. To burn a CD requires a CD burning software (Or you can use Itunes with little options to choose from) |
Oh, I got it
Thanks guys. Yesterday I realize that my problem Wasn´t at the bouce part, I don´t know why the headphone´s output of my PC sends me a mono sound when I use protools, so I though that the problem was at the bounce step. I bounced my project, I put I on a MPG3 file, I send it to my cellphone and it was on a steroe file But know I don´t know why when I use protools I can´t listen the stereo file when I´m in my project. but when I import any mp3, (any song), I can listen a stereo file in Protools, so Im a kind of ¡WTF! Thanks by replying |
Well couple of issues did you record a stereo file ? Do you have it outputting to stereo master fader?
Did you have a problem with your headphones ? do u have connections TRS 1/8" male
the file I reccord its ok, well no at all theres a weird beat all over the record, but that dosen´t matter yet, I will check that about the master fader, maybe theres a problem there.
My headphones are ok, they have a jack 6 mm and 3.6mm both work well, the problems persist only whe Im in my project, If I open any mp3 file on stereo I can listen the stereo config, but in my project it is always in mono, even if is in a stereo file with the .L and .R files exported. I don´t know If you can understand me Thanks by replying |
Cannot create new file because that file already exists | j4callen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-31-2010 08:29 AM |
How to Create Stereo from Mono | RussUK | Virtual Instruments | 1 | 08-03-2009 04:23 AM |
How to create L and R Stereo tracks | churchib | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-05-2008 03:58 PM |
How to create L and R Stereo tracks | churchib | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-04-2008 04:47 PM |
Can't Open/Create new file from File Menu | nob turner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-07-2003 11:04 PM |
