Old 11-08-2004, 11:24 AM
johnboymusic johnboymusic is offline
Default unusable audio drive
when i booted up my system this morning, protools said that my firewire drive (dedicated for audio) was unusable for audio - it tried to allocate the audio files to my system drive - nothing has changed since i used this session on friday (or has it?) - i've backed up the data and formatted the hard drive, copied the data back, and still have the same problems - i've tried other sessions and the same thing is happening - any suggestions? thank you so much
johnboy
Old 11-08-2004, 12:51 PM
alance alance is offline
Default Re: unusable audio drive
What does it say about your drive in the workspace? If it says anything but R in the A column, this could be your problem. Did you Format the drive with hfs ext. Not journaled? I'm assuming it is a 7200 oxford 911 bridge set drive. If not there's your problem.
Old 11-08-2004, 01:04 PM
WestPhillySoulzition WestPhillySoulzition is offline
I just got the same error. It says you must choose and audio record volume. I also use this volume for logic pro 7. But nothing has changed, I used ithe drive for PT 2 weeks ago. It is an internal 120 gig drive dedicated to audio with a 8 mb buffer.
any ideas?
www.Subglo.com
Old 11-08-2004, 01:07 PM
Actually it said
"session must be on an audio record volume"
this happens when I create a new session on that drive.
www.Subglo.com
Old 11-08-2004, 01:23 PM
Sorry about the triple reply, I figured it out. you have to open up the workspace in protools and make sure all of the drives are set to R in the A column and not P or A.
best
ryan
www.Subglo.com
Unusable audio -Frustrated wstrieder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-09-2008 06:14 PM
Valid Audio Drive (hard drive issue) MacPro / HD3 owenpop Pro Tools TDM Systems (Mac) 5 01-11-2008 12:28 PM
Audio on Unusable Volumes? Sradio Pro Tools TDM Systems (Mac) 4 10-18-2005 07:51 PM
Hard Drive Performance Dual Processors and Dedicated Audio Drive j_jayzatuc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-03-2000 05:52 PM
anyone using the system drive and storage audio drive in the same SCSI chain? riorecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-15-2000 11:09 PM
