Split Stereo to Interleaved Files
Hi
Looking for a quick solution to a big headache. Using Logic Pro/PT Mix 3 . I want to convert all my split stereo files at once to interleaved and have them import into my Logic song in the correct positions in my Logic arrange page. I simply want to convert a Logic/DAE project to a Logic non DAE one and have the split files interleave...without having to do them one at a time and manually import.. Is this possible...? Any help greatly appreciated. Thanks Jack's Hoose Music |
Re: Split Stereo to Interleaved Files
OMF export?
try Peak - it joins files and also has a batch converter
gina |
Select a stereo track and then use the "Export Selected as Files" in the audio Menu above the audio bin. You can select many different types SD2; aiff; WAV etc
Thanks Guys and Gals.
Sure Peak can do the conversions but its getting the little interleaved blighters to import in the song at the correct positions... Its a Logic DAE versus a Logic non DAE set up. If I try to get Logic to look at the new interleaved files it still asks where is file.R and file.L from the original song. I can point to the new interleaved file but the arrange page still displays the two sides of a split stereo file. ..arghh Thoughts anyone.. Thanks Ged Jack's Hoose Music Scotland |
OMF or consolidate all from 0 (stems) and export regions as interleaved
Stereo Fault Interleaved or split | HiLoc | macOS | 0 | 01-15-2014 02:20 AM |
Any batch software to combine split mono .L/.R files into interleaved WITH metadata? | Maskeeper | Post - Surround - Video | 8 | 12-23-2012 09:44 PM |
stereo Interleaved to split - quality | Uganda | Post - Surround - Video | 1 | 04-22-2008 12:50 AM |
SD II FILES ARE STEREO INTERLEAVED BUT WAV ISNT?? | Pete Weaver | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-19-2004 10:47 PM |
interleaved stereo files question | anders | Tips & Tricks | 4 | 09-24-2000 03:04 PM |
