Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 05-03-2021, 02:01 AM
timtech timtech is offline
Default Getting rid of a metallic twangy sound on electro acoustic
I have a guitar solo done on a Takamine guitar and it's slightly twangy - can that be remedied with EQ? I have pro Tools 11 with the usual EQ plug ins available including channel Strip etc. If you could put a screen shot on it would be useful, please.
Old 05-03-2021, 02:49 AM
Sardi Sardi is offline
What do you want a screenshot of/for? A preset isn’t going to help as it’s highly dependent on the source material.
Just grab the EQ7 plugin included in Pro Tools, set a narrowish Q on one of the mid bands, boost it and start sweeping the frequency spectrum until you start emphasising the problematic frequency. Once you’ve found it, invert the gain so your cutting not boosting and you’ll start to reduce the unwanted tone. I would also open up the Q otherwise you start to get a nasal like quality if it’s too sharp. If required, use a secondary band.
At the end of the day, you need to use your ears. You’re already halfway there in that you’ve identified something you don’t like. Now you just have to find it and try to correct it.
One last thing, once you’re happy with the EQ, play it in context to the rest of the mix. You might find the processing doesn’t need to be as drastic when other instruments are added as they may mask some of the offending frequencies.
Old 05-03-2021, 02:52 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Getting rid of a metallic twangy sound on electro acoustic
Also some harmonic processing like Sonnox Inflator may tame the problem a little, but what he ^ said is the first trick always.
Janne
Old 05-03-2021, 12:53 PM
What they said^^^, but you have the option(depending on the player's availability) to re-record the acoustic with a microphone(which almost always will sound better)
Old 06-04-2021, 01:24 PM
DlwLr DlwLr is offline
Just dropped by to say that I had a big, long, detailed question written out to try and get help getting rid of some unwanted sounds in slapped strings on an upright bass and happened to find this and it answered my question.
Try this, my friend, and thank you Sardi!
Metallic Sound When Trying to Record?? jamiehoye_ macOS 4 09-26-2015 05:19 PM
Pitch shift metallic sound problem K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-26-2003 03:55 PM
Crazy metallic sound in heaphones..please help! elwoodblues 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-10-2003 12:09 AM
How to record Electro-acoustic guitar? VK$$$ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-04-2003 06:52 AM
nasty metallic sound on mixdown problem Delusion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-08-2003 11:21 AM
