Old 04-14-2006, 11:57 PM
SublimeAndy SublimeAndy is offline
Default t-racks (the eq plug in) losing settings
i know there is somehtiny ou can download so that t racks doesn't lose the settings everytime you exit the plug in. where can i get it?
Old 04-15-2006, 12:10 AM
bb_aus bb_aus is offline
Default Re: t-racks (the eq plug in) losing settings
make sure you have the latest version
Old 04-15-2006, 09:34 AM
i don't, where do i get it?
Old 04-15-2006, 09:51 AM
spkguitar's Avatar
IKMultimedia.com
Click "Support" on the menu at the top.
then click:
"Access the User Area here".
Login and you should be able to download updates for the products that you are registered for.
Old 04-15-2006, 09:54 AM
PrestonKD PrestonKD is offline
Funny how people are looking for the same thing at the same time. I just figured out yesterday that t-racks eq wasn't saving settings. I found this out while setting up my new studio with brand new software and hardware - however I did not bother to install the new versions of the t-racks. I kept the version I already had from my original hardware a few years ago. I am going to install the new software when I get back to the studio and see if that solves the problem. In the event that it does not I found the following link last night after leaving the studio that looks like it will:
http://www.digidesign.com/download/plugs/bun/
Hope that helps.
Old 04-15-2006, 10:02 AM
daeron80 daeron80 is offline
With the demo versions of IK plugs, like those that came in the Ignition Pack, you have to remember to save every setting to IK's proprietary library for that plug (not the shared library like with most plugs), and reload from there for each instance every time you open the session. It's a pain, but that's free crippleware for ya. Sounds so good, it's easily worth putting up with, IMO. Can't wait to be able to afford the whole TRackS package for real.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 04-15-2006, 10:48 AM
spkguitar's Avatar
That is true, unless you install the updates that are available that solve that problem. That's what we're talking about.
Old 04-17-2006, 06:56 AM
TDub TDub is offline
Hey guys, great info, this has been bugging me ever since i started using it! Something simple to fix luckily. I'll do the update . . . however . . . I have the same issue with Amplitube LE on my system. Each time I open session, I need to go back in and choose the previous settings that i had. Any thoughts on this one?
thanks
TDub
TDub
Digi002 R with Command 8 - PTLE 8.03
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 04-17-2006, 07:08 AM
spkguitar's Avatar
Same solution: get the update. There are updates for all 3 IKMultimedia plugins that came in the original free bundle; T-Racks EQ, Amplitube LE, and Sampletank SE
Old 04-17-2006, 08:36 AM
Well, that's the best news I've heard in a year.
Running the default Modify option of the installer didn't change anything. The Reinstall option worked. But now the program acts a little buggy. For example, after making changes to an IK plug and saving the session, if I close the session, the whole program quits. I trashed my digibase folders and prefs, but that didn't solve it.
David J. Finnamore
ModDelay III losing settings Giannis Pro Tools 10 2 07-04-2012 02:45 PM
Losing Aux send settings ledogboy Pro Tools TDM Systems (Mac) 6 12-16-2006 08:36 PM
Losing plug in settings from HD to Mix Extreme Mixing Pro Tools TDM Systems (Mac) 5 08-16-2005 10:28 AM
BF Plugins Losing Settings Erik Sojdelius Pro Tools TDM Systems (Mac) 0 07-14-2005 05:11 AM
T-RackS not saving settings in PT LE 6.1.1 gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-01-2003 09:27 AM
