new Neyrinck Dolby E plug in
So this plug doesn't actually make 8 tracks of PT into a Dolby E pair--it preps the 8 ch. group for encoding on Dolby equipment? What is the advantage, other than faster-than-real-time encoding? The idea is that it could make my 8 tracks into a single (theoretically non-screw-uppable) file and the encoding would be automatic? But doesn't the Dolby E file have to layed down onto videotape in real time? We usually make PT sessions that have ALL the channels needed to do a layback for all channels of a video master all at once--4 tracks for the 4 PCM tracks and 16 tracks for 2 Dolby E pairs for D5. So with this plugin, the Dolby E encoded file would go into a new PT session w/ the PCM tracks, and then we'd layback from that PT session to the video master? How is this more efficient--it seems like an extra step?
Philip Perkins |
Re: new Neyrinck Dolby E plug in
Hi Phillip,
we are very interested ín this plg-in, cause we are planning 4 tapeless tv stations. As we discuss the dolby stuff and the problems with encoding and decoding (1 frame delay ) we decide to work without dolby e encoding. So here we are, we need the metadata in a 5.1 bwf file without encoding dolby e. Thats why neyrinck is useful. My 2 cents Jochen |
Philip Perkins |
1. You create your mixes. Let's work under the premise its a 5.1 and an Lt/Rt. 2. When you have your mixes bounced, you import them back into the timeline. 3. You select your mixes on the timeline, and load Paul's plug-in (I can't recall the official name). 4. You set the metadata, and a place to put the resulting file. The resulting file should be a watch folder on the Dolby DP600C. 5. When the Dolby DP600C sees a new file in the watch folder specified for Dolby E encoding, it starts encoding the file (I hear the time savings is on the order of 5:1). 6. When the Dolby DP600C completes the Dolby E encoding process, it puts the resulting 2 channel BWAV file where it was specified to do so. 7. You import the BWAV file from step 6 into Pro Tools via another of Paul's plug-ins. You choose what you want the offset to be (from -2 to +2 frames), and it spots it. 8. You can now output that file (non-dithered mixer) to the VTR for layback. There are two (2) of the Dolby DP600's. The DP600 does loudness (dialnorm) correction. The DP600C does loudness correction, Dolby E encoding, and a host of other file-based encode functions. The DP600C is more expensive (sorry if that's obvious).
So you see Phillip,
as Jonathan pointed out the dolby e and neyrinck workflow, thats why we don´t want to go this ......dolby e way. And its not the end of the story, cause non of the tv customers can hear dolby e. You have to decode dolby e and encode dolby ac3 for transmission with a known 2 frame delay. Question to Jonathan: isn´t it faster to record your 5.1 mix and the dolby stream back into PT in one process? For me bounce to disc is a time waste. You can´t stop and make changes and go on from that point . my 2 cents Jochen |
OK, so I think I see that the Neyrinck plug allows you to do the work of making the Dolby E stream faster than real time if you have a DPC600 hooked up to the PT system, therefor allowing a post house to make fuller use of their investment in the Dolby boxes. After thinking it through I don't see how it would help those of us who don't have the DPC600 gear very much. Even if we could get encoded in faster than real time we'd still need the Dolby E gear to decode during layback for QC.
I can see why you might want to avoid Dolby E altogether if you had the choice, but as a "content provider" for American TV networks it is NOT avoidable for us at the present time. Philip Perkins |
Sorry I'm a little confused
Is SoundCode for Broadcast Delivery the thing you're speaking of? It isn't linked from Neyrinck's product pages. |
Hey Folks-
I didn't make it to AES to ask this question. Do you need a Dolby DP600 in order to add metadata to the BWF that SoundCode for Broadcast produces? Or can you make the Dolby E BWF with SoundCode only and lay it back to HDCAM, Digbeta, etc? -PZ
Paul James Zahnley, CAS Re-recording Mixer Disher Sound http://www.imdb.com/name/nm1647841/ http://www.dishersound.com/ |
Neyrinck Introduces New Dolby Pro Logic Audio Plug-In for Pro Tools at IBC | dr sound | Post - Surround - Video | 3 | 08-28-2012 08:05 AM |
Neyrinck plug in for encoding/decoding Dolby E | Roz.w | Pro Tools TDM Systems (Mac) | 5 | 09-16-2009 06:33 AM |
DTS, Dolby Digital and Dolby E with Paul Neyrinck | Brent_Sydney | Post - Surround - Video | 4 | 05-08-2009 04:32 PM |
Neyrinck SoundCode Dolby E | emf1138 | Post - Surround - Video | 8 | 01-02-2008 06:35 PM |
Steering in Dolby plug versus Neyrinck | CD Productions | Post - Surround - Video | 6 | 03-30-2006 12:34 PM |
