Re: Parallel Task Optimizations - settings missing in 2021.3?
For comparison - here's how efficiently HandBrake uses all the CPU threads.
Pro Tools 2023.9 Ventura 13.6 |
I've found that Elastic Audio's X-Form uses all the cores if the audio file is divided into more clips.
Pro Tools Session 1 stereo audio track - 4:00 - 16bit - 44.1kHz - Interleaved No other programs running apart from UAD console and Activity Monitor. Mac CPU Usage: PT idle Mac CPU Usage: X-Form rendering after changing tempo (1 clip) Mac CPU Usage: X-Form rendering after changing tempo (Audio split into 8 clips) Time to process 1 clip 1:30 Time to process 8 clips 0:12 I chose to split the audio into 8 clips because my CPU has 8 cores. The clips were not consolidated into separate audio files. Processing time would probably be about 6 seconds if all the CPU threads could be used. I tried 16 clips, but still only 8 threads were used. PROBLEM Sometimes there are minor playback "glitches" at the clip boundaries. This doesn't happen when the tempo is changed back to the original 100% bpm.
Pro Tools 2023.9 Ventura 13.6 Last edited by Richard901; 04-04-2021 at 07:34 AM. |
Intuitively this makes sense to me. How would you parallelize DSP on a contiguous stream of audio without breaking it into chunks first? And if X-Form is an implementation of a a third party's algorithm (iZotope) then I'm not sure what Avid could do to improve that.
Richard901: I'm curious. If you split the audio into 16 clips do you see all 16 cores active during render? Where I'd like to see improvement is with clip-by-clip Audiosuite processing. I think this was mentioned up-thread. |
HandBrake uses all cores and threads when processing one video file (see post #11), but perhaps a video file is technically different to audio, as far as multi-threaded processing is concerned. . . . third party's algorithm (iZotope) - Yes, that would make it more difficult. Quote:
I suppose a lot of PT's code was written many years ago when multi-core processors were rare.
Thanks for the reply. And I should have specified 16 threads in my above comment, not cores. I think you caught my meaning.
This has been fixed in 2021.3.1.
avid.secure.force.com/pkb/articles/readme/Pro-Tools-2021-3-Release-Notes
• linkedin •
Thanks for the update.
2019.5 Different Disk Cache behaviour (depends on Parallel Task Optimizations) | bartosz idzi | Pro Tools 2019 | 0 | 05-16-2019 06:00 AM |
Parallel Task Optimisation | TrentWilliams | Pro Tools 2018 | 2 | 01-19-2019 03:51 AM |
Parallel Task Optimizations Preference? | zion | Pro Tools 12 | 18 | 01-19-2018 06:28 AM |
systems optimizations (100% cpu in the task manger) | MR808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-18-2003 02:14 AM |
