Old 07-23-2022, 05:37 AM
meshzu meshzu is offline
Default Black/blank video window on 2022.6 on OS 12.5
I was having a lot of problem with bounce to video since going M1 mac on monteray so decided to update the OS, and completely re-install pro tools (removed all related pref/set up files - a per avid instructions).
BIG PROBLEM> No video playback. Blank video window
Have tried re-installing, deleting prefs etc, deleting video engine prefs.
Really stuck
One mistake I have made is my OS is now 12.5 which is one point above the qualified version.
Any ideas?
Old 07-23-2022, 10:57 PM
Bigbottomend Bigbottomend is offline
Default Re: Black/blank video window on 2022.6 on OS 12.5
Are you using any 3rd party video hardware like Blackmagic or AJA? I had video engine issues when upgrading my Intel Mac to Monterey 12.4, turned out I needed to update drivers and firmware for my Blackmagic Mini Monitor.
Old 07-24-2022, 07:39 PM
bigbuddy3 bigbuddy3 is offline
HI,
I had the same black video issues but on Intel Mac Pro-12 Core, 2021.12 Mojave
The following worked for me:
Go to /Library/Application Support/Avid/AVX2_Plug-ins and empty the contents of this folder if any.
Go to /Users/Shared/AVidVideoEngine and delete this folder.
Hope this works for you too.
Peace
Old 07-25-2022, 05:32 PM
thanks for the advice. No video hardware, and had already tried the fixes with the folder locations with advice from support. Still nothing! arrrghhhhh
Old 07-25-2022, 08:10 PM
BScout BScout is offline
Are you using any scaling in display preferences? Turn that off (go to default) for all your screens.
Change all your colour profile settings to Apple RGB (for all your screens.) Do these things with Pro Tools closed. Then open Pro Tools and check if your video is back.
I have recently seen a situation similar to yours happen: all black or all green. It seems tied to scaling or colour space (I'm wondering if this is linked to the recently introduced Avid's/AVE's colour space options for video display; though changing those around did not fix it. Only changing the operating system's scaling and colour space fixed it)
Old 09-19-2022, 02:07 AM
19Josh02 19Josh02 is offline
Hi everyone,
I'm having the exact same issue with OS 12.5 (M1 Chip) and PT 2022.7 and cannot find any solution. Was anybody able to solve the problem?
Edit: I could later solve the problem with reinstalling Pro Tools. Maybe the problem was that i installed Pro Tools before i installed Blackmagic Desktop Video
No playback in video window - Video Window Remains black JJBG Pro Tools 2020 4 04-19-2020 06:50 PM
Black video window when playback lamacchiacosta Getting Started 5 04-10-2020 03:31 AM
Black Video Window No Letterbox Intransit Pro Tools 2018 14 01-15-2019 07:52 PM
No Video Playback (Black Video window and thumbs) winkelement Pro Tools 12 13 03-17-2016 11:03 AM
Help! Blank start up window on 5.1.1 Petermix Pro Tools TDM Systems (Mac) 0 09-03-2002 10:55 AM
