Why My Code From the Booklet doesn\'t Work?
I'm trying to download PT 6.4 for Windows XP. I have used this code many times to download Mac versions. The code which is on the inside of my booklet says PT TDM code for MAC OS X / WIN XP so I'm baffled as to why when I go to the archive download section and try to download the Windows XP 6.4.1 version which they say needs a code that starts with DIGI06 (which I'm using) it gives me an invalid autorization. PLEASE HELP!!!!
Dell Studio XPS 9100 12.0 GB RAM 6 processor cores Windows 7 64-bit operating system Display adapter type: ATI Radeon HD 5900 Series Total available graphics memory 4083 MB Dedicated graphics memory 1024 MB Dedicated system memory 0 MB Shared system memory 3059 MB Display adapter driver version 8.791.0.0 Primary monitor resolution 1680x1050 DirectX version DirectX 10 Pro Tools LE 8.0.4cs2 Mbox2 Mini |
Re: Why My Code From the Booklet doesn\'t Work?
Are you entering the code EXACTLY as you see it, including upper and lower case letters and spaces?
http://archive.digidesign.com/download/641/ I then click on the Pro Tools|24 MIX Core Downloads link and under the Downloads tab I click on Pro Tools TDM 6.4.1 for MIX Systems on Mac OS X 10.3 & Windows XP. It expands and I scrol down and click on the Pro Tools TDM 6.4.1 for MIX — Windows XP DOWNLOAD Link. It asks me to login, which I do. It then asks me for the Authorization Code which can be found in the product manual. I go to my booklet and type in my code. It then gives me this error. Warning: Software code specified is invalid. I see that you an administrator so if you want me to forward a picture of the code on the booklet I can but please help.
Send me an email at [email protected] with the following:
Name, address and email address that the system would be registered under. The exact code that you are trying to enter. I'll be able to troubleshoot from there and reply directly to you.
Administrator Avid Pro Audio Community |
The activation code inside my 002R manual had a group of digits and what looked like a space between it and the next group.
Turns out it was two spaces between instead of one. Hope this helps. GregJ |
lost my getting started booklet-need my serial | nirels | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-22-2012 01:41 PM |
Authorization code won't work | johnjm22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-21-2007 09:11 AM |
Lost Booklet... | Perticelli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-16-2006 01:59 PM |
HELP! 7.0 code will not work in a second computer! | DJHomeyJemal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-22-2006 04:10 PM |
Authorization code will not work | Da' Cono Men | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-12-2005 08:34 PM |
