Pro Tools / Avid Control App / iPad (8th Gen)
I'm a bit lost trying to get my iPad / Avid Control connected with my Pro Tools - setup .
The Avid Control - App shows a red triangle and the ethernet controllers search in PT / Perpherals, etc. finds no device . I have resetted all the devices, still with no success . I have installed the latest EuCon - Software . I'm using a TP Link WIFI - USB Dongle on a Windows 11 - system and all the devices are connected to this same device . Still no connection . Could use some help here, - Z- |
Re: Pro Tools / Avid Control App / iPad (8th Gen)
you connect it in eucon not the peripherals options.
How do I do that ... ?
You select 'Settings' in the Eucontrol app, and on the 'Surfaces' tab, select your device in the left panel, and click 'Add' to make it show up in the right panel.
Added: Also, you might want to go to the 'Assign' tab and select the three 'Lock to application' options at the bottom. That makes the ipad Control stay connected to PT even if you switch to another application on the mac. I like it that way.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. Last edited by Ben Jenssen; 07-30-2022 at 06:27 AM. |
I’m having hard times, when I try to run the App, that l find in the search of Windows “start menu” . It’s giving me an error code …, “Entry Point Not Found” . - Z - |
Sorry, I don't know about windows, I'm shure windows guys will help you. Are there not settings in the control panel?
What did you install? EuControl or EUCONWS? You need the former. When its running it will be an icon down in the notification taskbar.
The router is a Huawei E5377 4G/WiFi - mobile router . - Z - |
That is why you see nothing.
Avid control for ipad | tonyw7 | Avid S1, S3, Dock and Control App | 2 | 01-03-2022 08:26 PM |
Does PT First support Avid Control iPad app? | atkeyboards | Pro Tools | Intro Discussion | 4 | 02-13-2021 03:17 PM |
Avid Control with iPad on Windows 10? | atticmike | Pro Tools 2020 | 3 | 12-04-2020 09:53 AM |
S3 + iPad Running Avid Control | priorytools | Avid S1, S3, Dock and Control App | 0 | 06-07-2020 05:13 AM |
New Avid Pro Tools Control for iPad | nst7 | Avid S1, S3, Dock and Control App | 261 | 10-13-2015 12:33 PM |
