Our Glyph 1U Firewire enclosure disconnects the Western Digital JB800 80GB hard drive randomly. Unit comes with two IBM drives installed. Western is installed in an identical enclosure (storcase) I also use some Seagate drives and another IBM, no problems with them. Both Os 9.2.2 and 10.2.8 has same problem. It says " one of your fw drives stopped resp... try undoing what you did..." thing. Switching the power off/on sometimes helps, sometimes not. I have to reset G4. I had some problems before with the same drive (damaged files) and then reformat it within Os X with drive setup utility, there seemed to be no problems left. I'm also going to write to Glyph but I'd like to post here before for a quicker response.
HD3 + Control 24 + 2 192s Mac Pro 12 core 2.93 & PT 8 16 Gig RAM Glyph Firewires Motu MTP AV USB |
Quick things to check:
1. Were all drives formatted in the same manner? Using OS X Disk Utility? 2. Do all drives have their master/slave jumpers set the same? For FW enclosures, they should be set to Master or Single. |
My Glyph HD keeps getting ejected randomly | Sounds like...! | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 04-04-2010 10:56 PM |
002-Randomly losing firewire connection! | audiopunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-28-2007 10:23 PM |
O.T. Glyph Firewire doesn't unmount | Impala | Pro Tools TDM Systems (Mac) | 3 | 08-13-2003 11:21 AM |
002 + glyph firewire: use 1 or firewire cards | PDEES | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-08-2003 03:46 PM |
glyph firewire | 5milefall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-07-2000 02:22 PM |
