Old 05-08-2015, 08:12 PM
MarkH MarkH is offline
Default Utility plugins for volume boost
Logic, Ableton, and Cubase have "Utility" plugins to boost the audio signal of an external input. For example, if I have a Moog Voyager connected directly into my sound card the audio signal is a bit low because the Voyager is unbalanced. Inserting a Utility plugin allows me to increase the volume input. Does PT have a plugin like this?
Thanks,
Mark
Old 05-09-2015, 04:52 AM
Default Re: Utility plugins for volume boost
Thanks,
Mark
I'd first take a look at the back of your Voyager (I have a rack mount one). There's a switch to change the outputs from balanced to unbalanced. Second - turn up the volume on the Voyager from the front panel. You want to get as high a signal as possible (without overloading the a/d converter).
Remember that once a signal is in the computer anything you do is not actually going to boost the signal coming into the a/d converter. All you'd be doing is mucking about with the ones and zeros already in the computer. You could use a Trim plugin on the PT track that is receiving the external audio.
Truthfully if you're using a built-in soundcard (especially on a laptop) I'd ditch that and get a real external audio interface that will do justice to the Voyager output. It's too good of a synth to strangle with a crappy internal audio interface.
Jack
QAPLA!
Old 05-09-2015, 05:32 AM
Thanks for the reply. Unfortunately only the Voyager rack has the ability to do balanced output. The synth is only unbalanced.
I'm using an Orion32 sound card. It has 32 balanced inputs on 4xDB25 but it doesn't offer Mic/Line gain input like some other interfaces would. Balanced audio input is typically around -12dB which is where I think it should typically be?
Antelope does have an MP32 that will front-end the Orion32 with 32 Mic/Line inputs (4 can also be Hi Z) and the software allows you to control the gain, phantom power, etc, on each of the 32 channels. Perhaps that is the best way to go.
Old 05-09-2015, 06:42 AM
How about using a DI box? Radial has a couple of passive units that might work for you. There's the JDI Duplex:
http://www.radialeng.com/jdiduplex.php
and the JDI Stereo:
http://www.radialeng.com/jdistereo.php
The Radial stuff is built like a brick.
Jack
QAPLA!
Old 05-09-2015, 06:49 AM
The Trim plugin is my short term fix. I think the long term fix is buying an Unbalanced -> Balanced converter. They are the same size as a DI box and cost about $40. Thanks!
Old 05-09-2015, 10:50 AM
Those things are a cheap fix. Better to go with a true di; you'll get better sound.
Jack
QAPLA!
Looking for Pro Tools Utility Plugins tbond Windows 11 10-25-2013 12:45 PM
PT 11: Crazy random volume boost, track muting, and cliping sharchik Pro Tools 11 0 08-29-2013 08:53 PM
Volume boost without changing presets? Jd0g33 Eleven Rack 11 10-20-2011 01:13 PM
gain,volume and boost on the bogner timos Eleven Rack 3 04-03-2011 06:41 AM
HOW TO BOOST BOUNCE VOLUME? CRM-114 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 04-01-2002 10:10 AM
