Hey guys, is it possible to get a pure volume boost without changing presets. ive already tried the white boost after the amp but it just sounds like distorted crap... what do you guys do?
There's no reason the white boost shouldn't serve your purpose unless you're already running the levels at max. Use the metering function (found by scrolling all the way to the right in the rig chain) to check this.
You could also use MIDI or an expression pedal or a switch to alter the rig output level as required. |
I've used a graphic EQ for level boost in a lot of my patches, it works very well.
![]() Quote:
http://www.youtube.com/watch?v=1ZJerdunqVo Quote:
http://www.eurekasound.com/ http://www.youtube.com/watch?v=balu7aTDPmg
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
![]() Quote:
You can also use the EQ's to slam the input of the amp and/or also adjust the frequencies of the EQ to help carve the tone going into the amp, which will affect the sound coming out. Its a good technique to know, and I believe Chris has posted about this in his Eleven Rack Blog, however he is using the P-EQ http://community.avid.com/blogs/avid...-boosting.aspx http://community.avid.com/blogs/avid...even-rack.aspx
If you are using a crunchy or saturated patch to start with, putting a boost or overdrive or EQ in front of the amp won't make it get louder, it will just get more saturated. The boost needs to happen AFTER the input of the amp. That means the FX loop.
Since I don't have outboard FX in my FX loop, and my output is always set to "Rig Output", I use the old FX loop boost trick, and it works well if done correctly: Take a short 1/4" cable, and jumper the FX send to the FX return, and then in each preset, place the virtual FX loop after the cab block, and then turn the FX return level up. Assign a switch on your MIDI foot controller to send a CC that engages\disengages the loop. Now when you step on that switch, you get a boost. You have to adjust the "send" level too to avoid digital clipping, IIRC, but I don't remember the specifics. There is a good explanation over at elevenrackpresets.com... |
The best solution I have found is to use the Dyn Compressor POST amp stage. Just set the threshold at maximum and boost the volume however much you need with the gain knob. I have this on all my patches and use it as a solo boost. Works perfectly.
Guitars 2010 Rickenbacker 360, 1989 Gretsch Firebird, 2009 PRS Single Cut Trem, 2010 Fender Strat, 2001 Taylor 614ce Pedalboard Fulltone Clyde Wah, Boss FV-500h, Foxrox CC Hybrid Fuzz, Foxrox Octron, Foxrox Aquavibe, Foxrox ZIM, Xotic EP Booster, Boss TR-2, Korg Pitchblack, Rocktron MIDI Mate Amps Avid Eleven Rack :: My Photos :: My Facebook :: My Church |
Personally, all my patches have a graphic eq with a slight boost in mids, and over all volume for a solo boost.
![]() Quote:
Used in front of the amps to drive it a little harder for a little more pre-amp distortion. Used after the amp only for clean volume boost. I've found this to be the "cleanest" way to add pre-amp gain and volume boost.
![]() Quote:
The Graphic added a slight bit of coloration to the tone according to my ears.
PT 11: Crazy random volume boost, track muting, and cliping | sharchik | Pro Tools 11 | 0 | 08-29-2013 08:53 PM |
gain,volume and boost on the bogner | timos | Eleven Rack | 3 | 04-03-2011 06:41 AM |
Changing Xpand2 presets with Axiom pro 61 | Sofine | Virtual Instruments | 7 | 11-10-2009 02:54 AM |
Changing presets by midi | renholder | Tips & Tricks | 3 | 11-14-2006 11:54 PM |
HOW TO BOOST BOUNCE VOLUME? | CRM-114 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-01-2002 10:10 AM |
