floppy authorizations on G4?
I presently have my Pro Tools Mix system on a g3. I plan to go to a G4 and 6.1, but I want to transfer the 5.1 stuff as well, using a dual boot G4 that will let me run 5.1 in 9.2 and 6.1 in OSX. Here's the problem: I have a number of plug-ins (Digidesign and others) that I can't or don't want to upgrade to OSX and these require floppy authorization. So how do you authorize these older plugs on a computer that doesn't have a floppy drive?
Re: floppy authorizations on G4?
you can purchase a floppy drive for the G4
( superdrive ) but you will also have to make sure you get an Ilok and get your plug-ins setup on an ilok account before moving forward with 6.1 cheers georgia
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
Yeah, I've been made aware of the ilok and 6.1 situation. I'm not 100% sure about going to 6.1 TDM. I've already got 6.1 set up for Mbox and maybe I'll just stop there. I mainly want 6.1 for ReWire and MBox/LE does it just fine. I do definitely want to set up ProTools 5.1 and all the plugs I have for that on the G4. Obviously a USB floppy drive is the only way for authorizations. My only reluctance is that I once tried to authorize Digital Performer on a laptop with no built in floppy drive and the aftermarket drive didn't work for authorization, though it worked for everything else. I even called MOTU and they were aware of the problem, but, well, tough luck. Send us a bunch of bux for a DP upgrade. Anybody with experience using a smart disk 2x usb floppy drive for authorizations?
Are we having fun yet? |
Hello,
There are iLok copy protected versions of most Digi or Digi distributed plug-ins for OS 9. You can download the ilok versions at the following link: http://www.digidesign.com/download/plugs/mixmac.cfm For Floppies: Just make sure you use a supported floppy drive with the correct extensions. http://www.digidesign.com/compato/floppy.html Mike |
More Floppy info:
The currently supported floppy drives for the B&W G3/G4's are: -Imation SuperDisk -Newer Technology Udrive -VST Floppy Drive (model FDUSB-M only)--cheapest price $20 refurb ---------------------------------------- The Udrive requires version 1.0 of its drivers available at: http://www.newertech.com/software/drivers/index.html The Imation SuperDisk requires these drivers: -USBSuperDiskClassDriver v3.3 -USBSuperDiskUTDriver v3.3 both of these extensions are available (as a single download) from the following URL: http://www.imation.com The VST Floppy Drive requires the following driver: -USB Floppy Support 2.1.6, available at: http://www.smartdisk.com/downloads.asp All drives require the following extension: -USB Floppy Enabler 2.1.2- available at: http://www.paceap.com/dldrvr.html Mike |
I am also interested on moving my "floppy authorizations" to my ilok, I am currently using MacOS9.2.2 and ProTools|HD 5.3.1 but I want to move to 6.1 as soon as I get every plugin inside the ilok. How do I "move" my floppy authorizations to my ilok???? Digi plugs that I need to "move": -Sound Replacer -Drawmer Dynamics
Camilo Orozco Like us on www.facebook.com/artedigitalestudio www.estudiodegrabacion.com.mx |
Be sure to read the Digidesign iLok Information page:
http://www.digidesign.com/support/ilok Details there regarding the procedure to have your Digidesign and Digi-distributed plug-ins updated to iLok authorizations when you upgrade to Pro Tools 6. Information regarding floppy authorizations is on a number of pages in the compatibility documents for Pro Tools 6 on OS X, including the Optional Digidesign Plug-Ins page for each system, on the Mac OS X Requirements with Pro Tools 6.1 Systems page: http://www.digidesign.com/compato/osx/os.cfm and this page: http://www.digidesign.com/compato/osx/dual.cfm Pro Tools 6 and Migration to OS X — Dual-Boot Systems Using Pro Tools 6 for OS X and Pro Tools 5 for OS 9 on the same computer The iLok authorization will authorize the plug-ins on any supported operating system, OS X, OS 9, and Windows XP. You may have to update the plug-ins on OS 9 to an iLok compatible version. OS X versions are either on your Pro Tools CD, or downloadable from the web in most cases. For floppy authorizations that are not OS X compatible, you will want to read the links above if you are installing or updating Mac OS X. Floppy authorizations will not work at all in OS X, but you can authorize your hard drive for use in OS 9 with a compatible USB floppy drive. The Color Kit Edition is available, and is a supported floppy drive with pace authorization floppies. On the SmartDisk homepage, click on the upper left corner for web deals: http://www.smartdisk.com/BlowoutPricing.htm Other Products: USB Floppy Drives Titanium Edition - (Refurbished Model #: RF-FDUSB-TM) - $15.99 click here Color Kit Edition - (Refurbished Model #: RF-FDUSB-M) - $15.99 click here http://store.yahoo.com/smartdiskstore/flopdisdriv.html
Administrator Avid Pro Audio Community |
Digi support said this floppy drive was OK:
-VST Floppy Drive (model FDUSB-M only)--cheapest price $20 refurb However, it's not presently available as a refurb or new anywhere that I've been able to find. What's available is: RF-FDUSB-TM. Is that OK too. From the smartdisk site, it appears this is only a cosmetic variation. If you need a USP floppy drive, these are now only $15.99 refurb. |
Hi Mike - Digi
I am probably a moron but I bought the VST drive kit color you guys recommend and I just can not authorize my AMP farm 1.0 and 1.5 floppy original installers. I tried upgrading drivers and so. It says it can not read those types of disks and sometiems that the drive is not connected. So?
Alécio Costa Studio High-End e-Mastering & Music Production www.aleciocosta.com http://www.facebook.com/alecio.costa PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter. |
ALÉCIO,
According to your post in October: http://duc.digidesign.com/cgi-bin/ub...;f=16;t=015843 Quote:
Unless I'm mistaken, from everything you have written there and over the last several months, it sounds like you have an old NFR dealer copy of Amp Farm. If that is the case, it is not a retail version that can be registered as new or by transfer of ownership (and should not be given out by the dealer under any circumstances, as stated on the NFR license agreement). Otherwise you should have been able to register it by now and get support. Unless you own a legitimate copy of Amp Farm that can be registered and upgraded, Digidesign is not able to offer you support.
Floppy Authorizations on a Repartitioned HD | Dog BBQ | Pro Tools TDM Systems (Mac) | 3 | 01-26-2006 08:22 PM |
Floppy Authorizations to ilok | CHRIS AIKEN | Pro Tools TDM Systems (Mac) | 2 | 03-02-2005 07:52 PM |
old floppy authorizations with ilok, what to do? | digigirly | Pro Tools TDM Systems (Mac) | 2 | 09-08-2003 10:02 AM |
Anyone Used Imation Floppy For PACE Authorizations? | ChaplainPC | Pro Tools TDM Systems (Mac) | 11 | 02-21-2002 02:48 PM |
Suggestions on Floppy Authorizations on G4? | AVGuru1 | Pro Tools TDM Systems (Mac) | 7 | 09-27-2001 06:21 PM |
