Session Transfer by CD
Normally a session would be transfered by using the "session copy to" with or without audio files.
If it is necessary to transfer a session via CD, and you do not wish to go through the "ProTools was unable to find the file..." routine, is there a way to accomplish this transfer? Using MacOS 9, Toast for CD Burn... ...J ------------------------------------------------------------------------ |
Re: Session Transfer by CD
here is what i do,
consolidate all tracks and playlists (shift option 3) select unused audio files (shift-apple-u) delete unused audio files (shift apple b) next, go to the finder make sure all of your tracks are there in the audio files folder, now, if your audio files folder consists of more than 650 megs, make another folder titled audio files 2(or whatever you want) you have to do that, because of the cd's data storage limit next, burn a cd of the session, plugin settings and audio files one. then burn as many additional disks according to how many additional audio files folders you had to make. i know it sounds like a big process, but it is really not. remember, you should always check to see if it comes up on your own system before you take it anywhere. hope this helps, and i wasnt too confusing, i havent been up this early in a really long time. beau |
Session Transfer Help | Funkle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-11-2010 09:40 PM |
PT M-P on PC and PT LE on Mac - session transfer? | shalula | Pro Tools M-Powered (Win) | 2 | 08-31-2006 01:26 PM |
Transfer HD session to 001 and 002 | kid pro | Pro Tools TDM Systems (Mac) | 1 | 10-03-2003 04:44 PM |
Transfer session from Pc To Mac? | skman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-01-2000 08:00 PM |
24 bit Session Transfer to DAT... | Barron | Tips & Tricks | 2 | 04-17-2000 02:06 PM |
