I found an issue in Strike.
I have found an issue in Strike. Strike (at least on my machine) is not able to play a repeated pattern in "latch mode" and then at the same time, playing the note C1 to stop the pattern from playing and start triggering drum sounds individually from a MIDI track. ProTools will crash every time. I was able to remedy this by repeatedly triggering the pattern in "unlatch mode" and then begin playing the individual drum sounds from the MIDI channel.
This is the only way I was able to get this song to play. I have re-installed everything except my OS which I started to do until my Mac told me it would have to re-format my system drive and I just didn't want to go to the trouble since I was pretty sure that was not the problem. I hope this helps anyone that might run into this. |
Re: I found an issue in Strike.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Can you also send it to:
vi [at] digidesign [dot] com Please post your complete system specs here, as well as which specific troubleshooting steps you've done. Russ - I edited your email address to prevent it from getting bot farmed... |
I know OS 10.5.6 is not supported, but the problem existed on OS 10.5.5 w/ PT 7.4.2 as well as my current set-up.
System Specs: Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 2.8 GHz, 6 GB Graphics: kHW_ATIrv630Item, ATI Radeon HD 2600, spdisplays_pcie_device, 256 MB Memory Module: DIMM Riser B/DIMM 1, 2 GB, DDR2 FB-DIMM, 800 MHz Memory Module: DIMM Riser B/DIMM 2, 2 GB, DDR2 FB-DIMM, 800 MHz Memory Module: DIMM Riser A/DIMM 1, 1 GB, DDR2 FB-DIMM, 800 MHz Memory Module: DIMM Riser A/DIMM 2, 1 GB, DDR2 FB-DIMM, 800 MHz Bluetooth: Version 2.1.3f8, 2 service, 1 devices, 1 incoming serial ports Network Service: Ethernet 1, Ethernet, en0 PCI Card: ATI Radeon HD 2600, display, Slot-1 Serial ATA Device: WDC WD3200AAJS-41VWA1, 298.09 GB Serial ATA Device: ST31000340AS, 931.51 GB Parallel ATA Device: PIONEER DVD-RW DVR-112D USB Device: Keyboard Hub, (null) mA USB Device: Apple Optical USB Mouse, (null) mA USB Device: Apple Keyboard, (null) mA USB Device: GNX3K, (null) mA USB Device: iLok, (null) mA USB Device: Bluetooth USB Host Controller, (null) mA FireWire Device: built-in_hub, unknown_value, unknown_speed FireWire Device: Mbox 2 Pro, DIGIDESIGN, 400mbit_speed |
I have completed all that is listed in "General Troubleshooting - Pro Tools LE on Mac OS X". I have also deleted the two preference file you listed in one of my previous posts.
As I and DTS have already said - send the session then we can move closer to getting to a solution for you. HINT, HINT!!!
I'll try to get to it tonight. I am stuck at work till 5.
Did you get the session?
I did not get your email.
I am having some issues with my email so please email me back at wretaudio (at) hotmail (dot) com. |
STRIKE content not found [solved] | john1192 | Virtual Instruments | 34 | 11-04-2015 12:16 AM |
Strike - Content not found | Vincent Joly | The Drum Room | 5 | 10-02-2011 06:21 PM |
Where is Strike plug-in found in ProTools? | pafrodites | The Drum Room | 1 | 04-03-2010 01:43 PM |
Strike - Content not found | xq3js | Virtual Instruments | 18 | 09-29-2009 12:50 PM |
Strike Content File not found | atomicaudio | Virtual Instruments | 1 | 07-01-2007 06:55 AM |
