Re: Finally acoustic treating my room. I have a few Q's
I know the guy at RPG told you to put the dresser in the closet. That's cool, but looking at your room I don't think it'll make that much difference. You can try it if you want. But so long as it isn't directly beside you when you are sitting at the workstation it shouldn't be too much of an issue. Honestly, no matter where you move the workstation it will be tough to place the panels on either side of you. Normally they end up on the wall about 1/2 between where your speakers are and where you are. So with the current setup that is over the closet. If you move your daw to where your dresser is...then your panel is going to be straddling the door to get in and out. If you move it on the wall where the nightstand is it'll be straddling the door to the bathroom and if you move it to the wall that your bed is up against, it'll be straddling the window. So there really is no ideal setup. And because of that, I would suggest going with functionality first. Since you have so many doors and windows and stuff, you are probably better off putting the bass traps up between the ceiling and the walls. Kind of like this panel on the left above the keyboard is situated. http://www.realtraps.com/mini1.jpg That way you aren't closing off any doors or windows with them. as for where to put the panels and daw, you have to decide which wall you want your daw on and which door you want try and put the panels across. For me, I'd say leave it where it is and try to mount it on the closet door somehow. Or maybe cut the 2' piece down the middle and have two 1' wide panels, one on the door, and one on the wall next to the door. You'll have to see where the reflection point is before deciding what to do. Also, if you are going to center your bed on the opposite wall as the workstation AND you want to put diffusors up.... seriously think twice. The diffusors at that point will be on the wall right above your bed. And they are heavy since they are all wood... if you have a girlfriend and you guys start bumping the bed against the wall, the diffusors could come right down on top of you... which is painful and will probably kill the mood. ;-) If you are going to keep your bed where it is, then it probably isn't going to be a problem.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
I suggest starting with the minimum possible and adding to it over time. In the end you have to look at the purpose of the room and see if the income you are going to get justifies the money spent. Also things to consider... if you get a record deal... the label will pay to have someone else remix it anyway... if you are writing for film, the music gets mixed by the re-recording mixers anyway... If you are doing local bands... the room just has to be good enough to edit in. And you can try to get them to pony up the money for a studio to mix in. and so on and so forth... Acoustic treatment is very important and it is something that you'll never "outgrow" or become "obsolete" in future years. so it's good to have it and as you move into bigger spaces you can take it with you. But at the same time, you don't want to drop $2000 or $3000 in sound treatment yet if it's not going to bring in a return on your investment yet. Know what I mean? your room is basically 132 sq ft with 8' ceilings. Most studio control rooms are at least 300 or 400 sq ft with 10' ceilings and ideally you'd want something around 800+sq ft with 10' ceilings. Just keep that in mind.
Any thoughts guys?
Jim Carroll |
But really, I'm just trying to tame the room so it's actually worth buying better monitors. And when I do get better monitors, I want my mixes to sounds the same way on other systems as in my studio. I'm not sure which I should get first, but treating my room now seems like a smart move.
Jim Carroll |
They're very good. Quote:
Not sure how I'll manage to do this http://www.realtraps.com/mini1.jpg, but it would definitely look sweet and allow me to put some nice painting and posters on my walls Quote:
Jim Carroll |
From your drawing, you might also realize an improvement by moving your mix position back off the front wall. The "ideal" chair position is 38% back from the front wall(if you can make that work for your setup).
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
http://imgur.com/pfyjA.jpg
So I just found out the pricing on the IIG Minwool 4" thick panels... $24.26 for a pack of three 2' x 4' panels!! Cheaper than the OC 703! So I'm thinking about getting four packs (12 panels) and going from there. I know this room isn't ideal, but will it be worth putting these up in a configuration similar to what I've drawn out? And will my vocal isolation corner in the closet be effective? My estimated cost of this project is roughly $200 + w/e the cost of the diffusers are. Is this worth it? EDIT: So I'm thinking about following these plans for the diffuser: http://www.pmerecords.com/Diffusor.cfm Is there anything I should know about diffusion (specifically when it comes to room modes) before I begin building one of these? I know that in a room my size, absorption is the number one priority, but the rear wall is nearly 8 ft. (2.44 m) behind the sweet spot of the room, so I think a diffuser will really help get the room under control. I'm also considering using a less dense type of wood. Will this make the diffuser significantly less effective? I know I'm laying down a barrage of questions here, but I really want to do this right, and I'm on a college student budget, so it's not like I can hire an acoustician for the job! I appreciate all the help so far guys. I can always count on you DUC'ers
Jim Carroll |
The description of the diffusor looks good. It should do the trick for you. I forget the way to calculate how far from it you should be, but from what I remember it's something like a foot away for every inch deep the diffusor is. If it is 7 inches deep, then you should try to be at least 7' away if my memory serves me correctly. so long as you can do that it'll work well. The two things I would recommend from looking at your drawing... Move the panels on the ceiling foward. They are supposed to be on the ceiling between you and your speakers, just like the panels on the side walls are. you might want to try putting all three diffusors together at the back of the room instead of putting panels in between. Just a suggestion, try it both ways if you can and see if you like one way better than another. The reason being, the area on the back wall from which the speakers reflect off is pretty large... putting the diffusors together to make one big diffusor might (or might not) balance out the mix position a little more. It might not make that big of a difference. But if you have a way to stand them on something and experiment with placement before you attach them to the wall, I would recommend it. Also, I would try to make the lower right corner of the room (in your latest drawing) the mic area where you will record vocals. The closet will be so small that the resonant frequencies will be up in the midrange and give the voice a boxy sound. Having the vocalist out in the room will help keep the resonant frequencies lower. If you really want it in the closet, buy some more minwool and try ot put up 4" panels on as much of the wall surface as possible. Maybe even suspend the 4" panels off the wall by another 2" or so. The toughest part about the vocal booth is controlling 200~600Hz. So try to tune (using distance from wall) a couple of the panels so they can absorb down to 200 or 300 Hz. This is where a corner frictional absorber might come in handy... having it 2ft out from the corner would give you some absorption down to around 150Hz or so... So you might want to have a panel across the corner behind the singer (from floor to ceiling) that is 2ft out from the corner. Or maybe put one in both corners if you have room. Out in the room... if you can make membrane absorbers (usually you use 1/2" plywood and minwool but you have to seal it air tight, and leave an air gap inside between the minwool and plywood) for bass traps I would put a few of those (maybe 4 to 6) around the room. Since you can put them flat up against the wall and still get great bass absorption you can put them on the ceiling in the corner, or up against the walls in the middle of a wall or in a corner. Or if you can hang them across the corner if you want.
http://i.imgur.com/tsL3R.jpg (the green panels on the right wall are labeled 4 and 5. idk why my scanner cut it off)
Jim Carroll |
Acoustic Panelling My Room | fenderrocker | General Discussion | 2 | 07-23-2009 09:18 PM |
Treating a room for drums. | Travis Mitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-19-2004 02:32 AM |
Advice for treating MY room... | The Central Scrutinizer | General Discussion | 4 | 12-24-2003 04:06 AM |
room acoustic help | BesnikB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-26-2003 02:46 PM |
treating a small room | Ben Jenssen | Tips & Tricks | 3 | 05-22-2001 09:13 AM |
