Old 04-09-2003, 12:26 PM
BALLBURNS BALLBURNS is offline
Default Which new laptop works fine with Mbox
Hello
I just bought a Toshiba laptop p4 2.0 ghz with a hub usb 2.0 (not a 1.0 is it the problem?) and i always have crackling noises when recording after a small time
Is there a sure laptop which works fine with Mbox
or have i forgot something in my set up?
Thanks very much
Old 04-09-2003, 10:46 PM
Mr_Seven Mr_Seven is offline
Default Re: Which new laptop works fine with Mbox
2nd hard drive
Darren Valen
Cyberdream Studios
Old 04-10-2003, 12:17 AM
yo man yo man is offline
I remember reading it somewhere that you must connect MBox directly into USB port, otherwise if go thru hub, it will cause problem.
I just bought a MBox and a new sony laptop. so far so good! other than its latency.
Mbox CPU holding off USB audio. 002 works fine... Josh Fairhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-21-2010 02:11 AM
HP DV90610ev works fine with Mbox mini sonicapg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-19-2008 12:57 AM
My Mbox works fine on the SiS chipset system i have? antonzedd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-14-2003 05:19 PM
does midi w/ mbox works fine? Kelso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-22-2003 02:32 PM
Dell Inspiron 8200 works fine with Mbox ! Run Haugland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2003 10:31 AM
