I'm planning to use midi with my mbox. I will probably buy an oxygen 8, and I wanted to know:
-Does it work fine using the usb as a midi port (the O8 is supposed to support this), or is it necessary to buy a midi interface to use it with PT+mbox ? -Can I use the knobs with automation of plug-ins like I could do with a control surface? And also I'm looking for a virtual synth, which can support home-made sounds in wav, in 24 bits/ 48 kHz; I've seen sampletank couldn't even do that. do you have any Idee, not including an external expander? thanks for your help. |
up
Mbox CPU holding off USB audio. 002 works fine... | Josh Fairhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-21-2010 02:11 AM |
HP DV90610ev works fine with Mbox mini | sonicapg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-19-2008 12:57 AM |
My Mbox works fine on the SiS chipset system i have? | antonzedd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-14-2003 05:19 PM |
Which new laptop works fine with Mbox | BALLBURNS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-10-2003 12:17 AM |
Dell Inspiron 8200 works fine with Mbox ! | Run Haugland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-21-2003 10:31 AM |
