Mixing with headphones
The TB Isone Binaural speaker and room simulator is a VST plugin which cannot run in Pro Tools LE 8.05. The company that makes it discourages the use of a wrapper that would convert it to RTAS and they do say in their FAQ that it should not be used in Pro Tools. So, I have a bit of a dilema. I would love to have a perfect room setting where the monitors could produce a realistic playback but I do not have that and am searching for a plugin (or inexpensive hardware) that will work with Pro Tools. Could anyone make a few suggestions. I am familiar with "Redline Monitor". Anything else out there? Thanks! Dan
Signal Chain: Earthworks PM 40 piano micing System --> GML Pre amp--> Aurora 8 A/D Convertor --> Digidesign 003 Rack -- Dell XPS 8300 (i7-2600)(8GB Ram)(Windows 7 64bit)(ProTools 11.3.1) |
Re: Mixing with headphones
Redline works pretty well as RTAS. No complaints, but I wouldn't make a regular habit of mixing with headphones, at least not entirely. Even with a good sim, there's still no replacement for real monitors. I use it when I need to do a mix in a noisy environment or when I need to be quiet, but I avoid it whenever possible.
Also, when setting up a virtual monitoring system with headphones, it's good to have a speaker reference to go from. Then you can tweak until it sounds similar to your preferred monitoring, and you have a better idea of how it should sound.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Mixing on headphones? | calle.vs | Post - Surround - Video | 4 | 12-04-2009 09:49 PM |
Headphones for mixing! | TiPo | Pro Tools TDM Systems (Mac) | 14 | 11-24-2009 12:51 PM |
Mixing with headphones? | JonnyGinese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-04-2005 03:59 PM |
mixing with headphones? | friendlybunny | Post - Surround - Video | 1 | 02-27-2005 10:28 AM |
best headphones for mixing | audiocase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 04-15-2004 07:03 PM |
