Old 06-28-2021, 07:04 AM
audioluche audioluche is offline
Default 2021.6 install on the same drive as 2020.9.1
Pro Tools install question here:
When i had my 5.1 Mac Pro, i would just used two system drive, one for the newest Pro Tools install and the other with my "old" trusty system, meaning i could go back anytime to my latest version of Pro Tools if needed.
With my new Mac Pro (2019), i have only one system drive, so i am wondering how can i have a similar workflow with just one system drive?
I've read that some people rename the oldest Pro tools version in order to have 2 versions running at the same time, but i cant find the thread.
Is it possible?
Is there any issues related to this method?
I would like to try 2021.6 without overwriting my 2020.9 version.
Thanks for pointing me in the right direction!!!
Thanks
Luc
Old 06-28-2021, 07:41 AM
originalscottyg originalscottyg is online now
Default Re: 2021.6 install on the same drive as 2020.9.1
Just rename the older version of the app file within the Applications folder, then install the new version. You will then have both installed. The driver and firmware updates are usually backward compatible. I often use PT Prefs app to make a back up of my old prefs files for the old version, in case something gets whacky. And, most importantly, I always make a bootable clone using Carbon Copy Cloner before installing the new version.
Scott Gatteño
Old 07-01-2021, 10:11 AM
Thanks Scott!
So it's easy like that?
And both application will point to the plugin folder, pref folder, etc?
Cheers
Luc
Old 07-01-2021, 10:23 AM
Sardi Sardi is offline
Yep.
Old 07-01-2021, 11:56 AM
Originally Posted by audioluche View Post
Thanks Scott!
Cheers
Luc
File Type: png Screen Shot 2021-07-01 at 2.55.42 PM.png (57.8 KB, 0 views)
Scott Gatteño
Old 07-01-2021, 01:43 PM
Oh!!!
Ok, i see!
Nice collection!
Old 07-01-2021, 05:55 PM
Oh!!!
Ok, i see!
Nice collection!
More like too lazy to clear out the ones I don't use any more.
But it is really nice to install new versions and be able to roll back if needed.
Scott Gatteño
Old 07-01-2021, 06:06 PM
Ben Jenssen's Avatar
And of course, you can guarantee that different PT versions using the same prefs and libs and stuff won't cause problems?
Have you jumped between versions much to verify?
Old 07-01-2021, 07:46 PM
I use Pete Gate's app PT Prefs to back up my prefs in general. Then, when I am installing a new version, I duplicate the backup folder and label it with the PT version so I have a backup of the backup that's tied to a specific version. That way, if I need to roll back, I know I have a clean set of prefs that are known to work with a specific version.
But I actually haven't had many if any issues jumping back and forth between versions. Of course, there are certain version jumps where there can be certain incompatibilities, like a version where they re-wrote the Workspace Catalog databases, and once updated, they couldn't be reverted. But on first launch of the new version, PT threw up a warning and suggested backing up the old database in case the conversion to the new format got corrupted. I don't really use Workspace Catalogs, so it wasn't an issue for me.
Scott Gatteño
Old 07-01-2021, 07:50 PM
Well, thanks for clearing that up.
Hd Native with ProTools 2020 & 2021 lagol Pro Tools 2020 6 04-17-2021 09:58 AM
Rolled back to 2020.12 from 2021.3 ejinbc Windows 2 03-27-2021 04:40 PM
Why subforms 2019, 2020, 2021 ? EdgarRothermich Pro Tools 2020 5 03-25-2021 11:15 AM
Anyone having issues with Security Update 2021-002 (Mojave) and PT 2020.12? Cacov Pro Tools 2020 3 02-28-2021 04:22 AM
Avid announces Pro Tools 2020, 2021 and 2022! off the wall Pro Tools 2018 2 04-01-2019 08:50 AM
