Tremolo Plugin That Will Sync To Tempo?
Can anyone recommend a good tremolo plugin that will let me specify a tempo for the rate? I'm trying to track some guitars with a very abrupt (sort of "all or nothing") tremolo effect using amplitube for the effect, but it's controls just aren't detailed enough to allow me to lock the part to the drums. Any suggestions? Thanks!
Kyle
I've seen a million faces, and I've rocked them all. |
Re: Tremolo Plugin That Will Sync To Tempo?
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
I had to make this happen in a pinch, and I didn't have either of those plugs, so I drew a zigzag waveform in a track to automate the volume. Worked great, don't laugh. Probably not the best use of system resources either.
664 The Neighbor of the Beast |
Max, you're right on with that one. I learned that one, too. It's free and you can print it if you need to free up the rtas slot/resource.
When I learned how to do that, I was proud to 'make' it happen from existing tools, rather than purchasing the effect. GregJ |
Another good trick is to create a grid and cut out every other sliver.. makes a totally deep (to nothing!) hole between pulses that sounds very modern
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
PT8 click and plugin tempo or sync issue | GutenMorgen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-16-2012 03:34 AM |
Tempo Locked Tremolo | anackman | Tips & Tricks | 6 | 03-20-2011 08:02 PM |
Amp Farm Tremolo Tempo Question | Armando | Pro Tools TDM Systems (Mac) | 0 | 11-11-2002 05:28 PM |
B4 as tremolo/tube amp plugin | Mystic | Tips & Tricks | 3 | 05-02-2002 08:36 AM |
Sync Processor's Tremolo to Midi Time Sync via Interface | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-01-2000 12:08 AM |
