Old 01-10-2010, 04:06 PM
Dabeed Dabeed is offline
Lightbulb Feature Request: "Trim" as Automation Mode
The Trim plug-in is useful for trimming volume automation, but wouldn't it be cool if Trim were just another automation mode for a track? Just switch a track to Trim mode and then the fader moves the automation up or down, for easier mixing with other, non-volume-automated tracks. In Trim mode, if you didn't touch the fader, it would be the same as Read mode, playing back what's there, but if you moved the fader, it would trim all the automation. How cool would that be?
Old 01-10-2010, 04:13 PM
Top Jimmy's Avatar
Default Re: Feature Request: "Trim" as Automation Mode
Trim automation mode is only available in HD.
James Cadwallader
Old 01-10-2010, 05:53 PM
therecordinghouse therecordinghouse is offline
in LE, you can trim automation simply by putting a trim plugin as the last insert. yep, its that simple.
and if you want to use a fader, "flip" the plugin to a fader on your 002 or 003 control surface.
Lynn Graber
Studio and Mobile Recording, Fort Wayne, IN.
Old 01-12-2010, 03:27 AM
RiF RiF is offline
Actually I like using the Trim plugin for automation as it is. I can place it anywhere I want. As the first plugin for muting/fading out unwanted noise or as the last plugin for gain rides.
A built-in trim feature at the start of a channel's signal chain would make sense to me, though because it would mimic a real console.
Old 01-15-2010, 09:11 PM
Kinh Kinh is offline
The Kinh is confused??? The last two are correct you can use trim as automation and you can use it without while volume is automated.
Please dont confuse the Kinh
Old 01-15-2010, 09:16 PM
spicemix spicemix is offline
What we want is for them to stop making features HD-only that aren't intrinsic benefits of the HD hardware.
Peter Jensen
spicemix
Old 01-15-2010, 10:01 PM
Top Jimmy's Avatar
What the OP is referring to is another automation mode known as trim. You know: read, write, touch, latch and trim. Trim can be paired with read, touch and latch. In trim mode, the automation data can be modified in a relative way rather than an absolute way. Yes, you can also do this with a trim plugin, but having it as an automation mode makes things a little easier.
James Cadwallader
Old 01-16-2010, 03:35 AM
Shan's Avatar
Shan Shan is offline
The ability to do a fast global trim on all automation in a track has always been in all versions PT HD & LE before it was even implemented as an HD only feature.
Place a breakpoint just past the last region in a track, switch to the trim tool, place it just past the new breakpoint you created and adjust the automation on a global level for the entire track. This also works with edit groups.
Hope that helps.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 01-16-2010, 12:03 PM
frantik frantik is offline
wouldn't it be easier to just hit ctrl-a (select all) and use the trim tool?
Trikome.com - blog
PTMP 8.0.1 // FLStudio 9 // WinXP SP3 // Axiom Pro 49 // Delta 44 // Mackie HR624 // AKG K701 // Emu 6400 Classic
Old 01-16-2010, 05:14 PM
Shan's Avatar
You'd have to put the trim tool just past and to the right of the very last region in the track, in which, you wouldn't need to invoke ctrl+a at all.
Placing the trim tool anywhere there is no region and the automation line is at the default level will do a global trim also. That method I would approach with caution though, especially with edit groups on. Placing the trim tool past the last region with an extra breakpoint adds a "safety" point. Both methods work once one wraps their head around the workings of it.
Hope that helps.
Shane
Feature Request: Assignable "Midi faders" Xill Artist Series 4 10-29-2011 11:15 AM
Feature Request, enable trim automation JR Fountain Artist Series 8 03-18-2011 01:19 PM
"import tracks" feature request Tim R. Pro Tools TDM Systems (Mac) 5 06-05-2002 11:47 AM
Feature Request: "Show Markers" in Big Counter Display s2n Pro Tools TDM Systems (Mac) 1 12-21-2001 10:02 AM
Feature Request: Trimmer/Timestretch "Region Pad" s2n Pro Tools TDM Systems (Mac) 2 12-20-2001 10:47 PM
