Old 04-05-2006, 09:00 PM
Neodustin Neodustin is offline
Default Static/White Noise
I'm having some trouble with some recording I've been
trying to do. I'm still fairly new with Pro Tools and I have a
problem I constantly encounter. I have my Mbox 1 set up and I
record with an SM57. My problem is that whenever I try to
record a track, when the recording is rolling and I'm not
playing, there is a very loud static. Yet when I strum a chord
on my guitar, the static goes away and when the chord stops
ringing, the static resumes. I have everything set up
correctly that I know of, I assigned it to record from the
proper input, I set my trim so that it's not peaking and
everything else is in proper order. Does anyone have any advice
that could remedy this?
Old 04-06-2006, 04:21 PM
steve at Your Heaven steve at Your Heaven is offline
Default Re: Static/White Noise
Use the JUMP button below to post on the PTools LE forum where you see MBox listed. This forum is TDM, uses different hardware, and it's almost certainly a hardware issue (unless you have some extreme compression going on a track that brings up the background noise when the desired signal drops out).
steve
Your Heaven
static white noise Rawer macOS 15 03-31-2013 01:16 PM
Static/white noise during playback Harveyt101 Pro Tools M-Powered (Win) 10 09-03-2010 04:56 AM
Static noise (aka White noise ) During playback. =/ PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-23-2010 04:06 PM
Static (white noise) on Mic inputs 3 & 4 elankf1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-01-2006 12:20 PM
random white noise/static nostatic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-13-2003 05:29 PM
