Old 02-10-2004, 10:52 AM
optymusblu optymusblu is offline
Default Seperating one session into two tracks
I want to do a song that is going to feed into another song but I want them on seperate tracks.How would I go about doing this?
Learning,learning,and more learning!
THANKS TO THE DUC!
****OptymusBlu****
Old 02-10-2004, 11:01 AM
Bazzle Bazzle is offline
Default Re: Seperating one session into two tracks
Explain what you want to do a little more
Bazzle
Old 02-10-2004, 11:36 AM
O k,i want to take two of my songs(totally seperate songs)song 1 and song 2.Song 1 begins on track 3 on my cd it plays all the way through till the end of the song.At the end of the song it stops and the guitar keeps feedbacking.Then out of nowhere song 2 kicks in while the guitar is still feedbacking.I dont want song 2 to be on the same track(3) as song 1 because then you would have to listen to song 1 to get to song 2(or fastforward it)i want song 2 to be on track 4.so the only way I can figure to have this happen is to record song 1(drums) in a session on pt,then at the end of the drum track for song 1 sroll about ten seconds then record the drum track for song 2.Then record the rest of the instruments to both songs.When I record the guitar to song 1 let it feedback into song 2.But then I have both of these songs on one session in pt.one session to bounce down to disc one session to master,and one track(wich is not what I want, I want it two seperate tracks) How do I cut these into two different tracks?I hope this makes since.
THANKS TO THE DUC!
****OptymusBlu****
Old 02-10-2004, 11:49 AM
Why don't you record the two songs in different sessions.Mix them the way you like, then put the album together in a Stereo editing program like Sound Forge etc.All you need to do is drop a marker in your master so the CD reads it as tr/1 tr/2 etc.
Bazzle
Old 02-10-2004, 12:16 PM
storm-01 storm-01 is offline
Nero 6.0 has an option of cutting out the silence in between tracks. I think this is what you want, because there is not lag between the two songs. It is almost a seemless transition.
Old 02-10-2004, 12:22 PM
where02190 where02190 is offline
Tell whoever is mastering the CD to crossfade the two songs at specified points in time.
Old 02-10-2004, 01:32 PM
Jorge442 Jorge442 is offline
do the bounce, then on the stereo file, find a zero crossing (at the beginning of song 2) and hit ¨separate tracks¨ (I forget the shortcut right now). Now you have 2 sections which you can select and ¨export as file¨ as track 3 and 4. On the burning software choose zero spacing between the tracks....
There are other ways of doing it......I´d just let the feedback go on at the end of song one for example, instead of having both songs on one session.
have fun!!
jorge
what a long, strange trip it´s been
www.abacomusic.com
Old 02-10-2004, 02:33 PM
I think that's the important thing, don't try to do it all in one session file.You'll find a way to assemble the tracks after you've got them recorded
Bazzle
Old 02-10-2004, 02:51 PM
lemix's Avatar
lemix lemix is offline
Quite simple, really...follow where 's advice ;
Just mix the two songs to your liking, leave that feedback gtr. long, clean (no other tracks open, leaking into it). Your mastering dude can simply x-fade them, using the overlap lenght you'll specify. Track index markers placing can be a bit tricky>> too early = longer feedback before song #2 kicks in....too late= chopped off top of song #2 when played back off the replicated CD.
Burn test CDRs and test them out on different brand of players.
hope this helps...
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 02-11-2004, 01:05 PM
I will be mastering the cd myself.If I just did it in two sessions letting the feed back go at the end of song 1,and starting song 2 with feedback then after mastering the songs place them right by each other on the final cd will that do the trick?
THANKS TO THE DUC!
****OptymusBlu****
seperating midi notes on different tracks? brokemusician3 Pro Tools TDM Systems (Mac) 3 05-08-2008 12:00 PM
seperating midi notes into individual tracks. tempest1226 MIDI 6 01-27-2008 07:58 AM
Seperating Reason Drum tracks to Pro Tools soundboy35 Pro Tools TDM Systems (Mac) 2 06-01-2006 03:38 PM
seperating tracks, setting master DB levels farside 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-14-2005 09:45 AM
Seperating songs in one session? rocknrollcowboy Tips & Tricks 2 05-09-2005 02:38 PM
