Old 04-05-2001, 09:12 PM
tomazizio tomazizio is offline
Default Pro Tools5.1/Digi001 won\'t work after Firmware Update!
help i'm on a G4 500 dual (agp/gigabit) with 192 mb (used to be 512 before this @#$@#$ update). i'll open a session with and without plug-ins and everything will work, except that no audio will come out. is anybody having this problem also?
thanx and good luck to you all!
G4@500MP
Deskstar 40Gb ATA
Adaptec2940U2W
Seagate 7200 Barracuda 18Gb (2) SCSI
Quantum 6Gb ATA
Digi001
Old 04-06-2001, 08:05 AM
DigiTechSupt's Avatar
Default Re: Pro Tools5.1/Digi001 won\'t work after Firmware Update!
-Reseat the Digi001 interface cable at both ends.
-Make sure the Monitor Mode button is in the Out position.
Brent
Avid Audio Tech Support
Support FAQ
Old 04-06-2001, 08:03 PM
than k you brent for your answer, but unfortunately i already did what you recomend & its still no go, i'm baffled, basically it's no output city, but........ hell i don't know! thank you for your time!!!
Old 04-07-2001, 12:03 AM
shaggy shaggy is offline
Was this the dreaded RAM eating firmware update Apple is warning people about?
Any chance the 001 card was seated in the Mac when running this update?
Just a thought...
`oooO`
"The original nipper" Throw me a bone (Telefunken DI is ok too)
Old 04-08-2001, 02:15 PM
jdreeves jdreeves is offline
`oooO`[/B]
i installed the firmware update this afternoon, and my computer now won't boot up with the 001 card installed -- I get a white screen with a cryptic error code.
My card *was* in the machine when I installed the update - should that matter?
anyone else having this problem?
Old 04-08-2001, 02:21 PM
It's booting into open firmware?
can you type set-defaults -> enter -> reset-all -> enter
You can boot into into OF with (Option, Command O, F) keys.
- Zap P RAM (Option, Command, P, R) hold for three start-up chimes
This should really be done first.
See if that helps. Otherwise get on the phone with Apple. Dual Processor?
??Don't you have to disable one of the processors for the 001??
[This message has been edited by shaggy (edited April 08, 2001).]
Old 04-08-2001, 03:19 PM
eboe eboe is offline
hi
sorry to hear that...
maybe this can help you....
http://www.versiontracker.com/moreinfo.fcgi?id=10415
Old 04-09-2001, 03:16 AM
Armando Armando is offline
I use a G4 500Mhz AGP(SP) and did the Firmware update with the 001 card installed AND also installed OS X on seperate partition. No problems at all. I'm running PT LE 5.1.
Armando
Old 04-09-2001, 07:27 AM
RobbaDobba RobbaDobba is offline
Can someone clarify or point us to the firmware update you're talking about?
Thanks.
One good thing about music: when it hits, you feel no pain. --Bob Marley
Rig: MacBook Pro (15,1) 6-Core i7 2.6GHz / 32GB RAM / OS 13.6.6 / PT 2023.12.1 / Waves Horizon v14 / iZotope Music Production Suite 6.5 / Focusrite Clarett 4pre USB / Apple SSD AP1024M 1 TB (System), Samsung T5 SSD 1 TB (Audio) / Cal-Digit TS3 Plus TB3 Dock / Genelec 1030A Monitors
Old 04-10-2001, 02:58 AM
re seated the digi and now it's working!
wierd!
thank you for your concern!
also the card was in during 'firmware bonanza'. maybe that was it, i don't know!
HD Native cant Update Firmware after installing PT9.0.5 Update Aditu Pro Tools HDX & HD Native Systems (Win) 72 11-27-2012 03:57 PM
Firmware Update HELP. My 003 Rack will not update Firmware. New003RackUser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-17-2007 09:01 AM
Update Firmware? tempest18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2005 01:57 PM
pro tools5.1 digi 001 win98se LadyElectrikStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-18-2002 08:21 PM
pro tools5.1 digi 001 win98se LadyElectrikStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-18-2002 07:39 PM
