Old 07-26-2013, 11:26 AM
dwaynedelario dwaynedelario is offline
Default Modify Group By Selection
I'm on PT10.3.3, and I just tried to modify a group by selecting the desired tracks and hitting Command+G, but when I went to select the group I wanted to modify it was greyed out. When did this change? Now you have to go back to manually modifying groups and adding/subtracting tracks one at a time? in the group window?
Old 07-29-2013, 02:14 AM
Stig Eliassen's Avatar
Default Re: Modify Group By Selection
The shortcut to modify a group is Ctrl+Cmd+G.
Old 07-29-2013, 09:25 AM
Thanks Stig, but this isn't what I am looking for. I am trying to avoid using the modify groups Add/Remove tracks function by reselecting tracks in the edit window and reconfiguring a group based on that selection. Check out this tip from SoundOnSound I found from a ways back:
http://www.soundonsound.com/sos/sep0.../keypoints.htm
Halfway down the page under "Miscellaneous But Useful Shortcuts," second to last tip.
Old 07-29-2013, 09:28 AM
Got it. It's under the "Use Track Selection from Mix/Edit Window" :)
Old 07-29-2013, 10:39 AM
Cool. Ctrl+Cmd+G, and then choose Replace. Thanks.
PT(HD)11 bug - modify group (in edit window) = CRASH SimonThornton macOS 7 06-22-2013 06:15 PM
10.2 Group selection bug? Felix Rost macOS 2 08-18-2012 06:14 AM
group "modify" bug travista00 Pro Tools TDM Systems (Mac) 4 07-27-2007 09:23 AM
Modify DIGI GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-13-2007 06:58 PM
playlist selection by group? Ray Lyon Tips & Tricks 1 02-02-2001 11:15 PM
