Old 03-26-2013, 11:34 AM
jsbeeth jsbeeth is offline
Default Protools slow and sludgy after video import
Working on a scoring project in PT (v8 LE), and everything was fine with the first temp video file, but upon importing a new cut (same size, length, and file type [.mov] as the original), protools has become super slow and essentially unworkable. I've trashed prefs, and my system usage is only maxing out at around 25-30%, and I don't have a crazy track count or plugin load. It seems to be something about the new video file, but I'm not sure what it could be or what to do.
Any ideas? Thanks!
Old 03-26-2013, 12:03 PM
lancemcv's Avatar
lancemcv lancemcv is offline
Default Re: Protools slow and sludgy after video import
Is it the same video codec / data rate as the first video? Open them in QuickTime and get info to see if they are, also check the frame rates. Try bringing in the old movie and see if its still better, if so its most likely the new movie has an issue.
Old 03-26-2013, 01:30 PM
Yes, codec/data etc seems to be the same. Going back to previous session with the old movie works much better.
Old 03-26-2013, 06:11 PM
Craig F Craig F is offline
is the original silent and the new one have audio?
there was a problem with Quicktimes that had audio around this vintage
Thank you,
Craig
Old 03-26-2013, 06:27 PM
Both movie files had audio and as far as I could tell had nearly identical specs. In any case, they rebounced another file which seems to be working better, but I have no idea why! Thanks everyone.
Old 03-29-2013, 08:22 AM
reichman's Avatar
reichman reichman is offline
If it happens again, try remuxing the Quicktime to a Photo JPEG with no sound. PJPEG is pretty snappy with Pro Tools. Good luck.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
LinkedIn |
Immersive Master Pro
HTML code is On
Import video slow down Pro Tools danilaur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-14-2011 01:37 AM
Video import very slow... JR Fountain Post - Surround - Video 0 10-28-2009 06:19 AM
ProTools HD 7.4 - Can't import video file. HELP!!!!!! jayprotools Pro Tools TDM Systems (Mac) 3 04-09-2008 05:16 PM
Import video and audio slow CharlotteMichele Pro Tools TDM Systems (Mac) 1 08-27-2007 07:46 AM
Protools LE Mbox2: Video Import ? afox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-02-2006 12:24 AM
