Old 10-24-2012, 02:29 PM
Kevin Peters Kevin Peters is offline
Default Scrub Issue - Native vs. TDM Plugins
Scenario:
I have a Pro Tools 10 HD session up with two tracks and the same audio file on each track. I put the same plugin on each track, but one is the native (or RTAS) version and the other is the DSP (or TDM) version.
Say the plugin is a simple EQ, and I put the same curves on both plugins. Then when I scrub the region on the track with the native version of the EQ, I hear the region as is, as if it bypasses the plugin information. But when I scrub on the other track with the TDM plugin, I hear the region as if it passes through the plugin with all the EQ curves that I set (as expected).
Questions:
Am I missing something very simple here? Is this normal behavior for native plugins? And its not just EQs, I've tried it with a handful of other plugins.
The interesting thing is when I try it at home with Pro Tools 10 (non-HD, so all the plugins are RTAS), when I scrub it passes through all the plugins on the track.
I don't have the exact tech specs off hand right now, but I've tried it on two Mac Pros with Pro Tools 10 HD. My home computer is a Macbook Pro. I can get the exact tech specs if anyone thinks that would help.
Old 10-26-2012, 09:28 AM
Default Re: Scrub Issue - Native vs. TDM Plugins
I've just tested the same scenario in Pro Tools 8 on the same systems and it does the same exact thing.
Edit* I've also tested this issue on Pro Tool 6 with the same results. So obviously this has been around for a long time, I'm just surprised I can't find anyone else complaining about this before now. I guess in the past if you had a system with DSP, you always just use the TDM plugins so thats why no one would have noticed.
Can anyone try this out and confirm?
Last edited by Kevin Peters; 10-26-2012 at 01:33 PM. Reason: Additional Information
Old 12-06-2012, 06:42 PM
DigiTechSupt's Avatar
After a bit of digging with Engineering it looks like this is indeed a limitation of RTAS plug-ins running on TDM (HD/Accel) hardware.
Best thing we could recommend at this point would be to post it to http://protools.ideascale.com
Sorry that we don't have better news here.
Avid Audio Tech Support
Support FAQ
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
Native Instruments Plugins / PT 10 Issue everlast88az Pro Tools 10 0 11-19-2012 01:52 PM
Ctrl+Scrub Wheel issue kptkarl ICON & C|24 6 11-03-2011 04:51 PM
Serious scrub issue Compression Records Pro Tools TDM Systems (Mac) 4 05-19-2005 07:35 AM
HD/Ignitor/os9/5.3.1/Scrub Sync issue NK Pro Tools TDM Systems (Mac) 0 09-30-2003 12:00 PM
