Old 12-19-2011, 02:36 AM
mrpollack's Avatar
mrpollack mrpollack is offline
Default Can not open last session !It says it was created with older version of PT !?! WTF ?!
It's insane..Crash few times in every hour..I need to finish my album this week !! I press ctrl+s every 10 seconds to go forward somehow.. and now this... How it is possible that it can not open session I was working few minuts ago and it says that it was created on older version of PT ?!?!? Help !
Musician,Producer etc..
PT|HD Ultimate Native , UAD-2 Octo x2 , Win 10 Pro 64 bit, AMD ThreadRipper 3960X (24 cores 3,7Ghz (48 threads), 64 GB G.Tech DDR4 3200MHZ ,Gigabyte TRX40 Designare (with Thunderbolt), (Philips 40'LED screan) , Samsung 24" LED 2x192 I/O, Nuendo 4.3, Wavelab 6, Halion 3.5, Yamaha 02R96V2, AvalonAD2022, AvalonVt737sp etc... www.MrPollack.pl ,www.facebook.com/polak.bros.studio
Old 12-19-2011, 02:59 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Can not open last session !It says it was created with older version of PT !?! WT
Error messages aren't always right, more just as close as they can be to the issue! more likely the session got corrupted somehow, probably when it crashed last.
what about the back-ups and previously saved versions?
also start a new session and use import session data! this will probably give an error when you get to the track that has the problem, but see how far you get.
as always trash the prefs if you're getting crashes often and make sure ALL plugins are up to date.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-19-2011, 10:45 AM
mrpollack's Avatar
Hi
For some reason PT didn't make any session backup with this particular number ?!?! I tried import session data but it says the same as trying to open a session "created with older version of PT".. Also I can't solo a single channel in this one particular session.Processor goes to max and PT crashes..Nice....I use Halion 3 as a sampler with VST to rtas adpter..But I use it also in other sessions with no problem..
Got a msg saying that the session has been created by a older version.. officialcath Pro Tools M-Powered (Win) 2 12-24-2012 12:20 PM
Can't open session it's created with an older version of PT James Drake Pro Tools TDM Systems (Mac) 6 08-22-2011 08:17 AM
Cannot open session in Mpowered7.3 (created in 7.3 but gives "older version" error) Krizaps Pro Tools M-Powered (Mac) 3 02-18-2011 12:31 AM
URGENT; cant open session, created with older version. kyle_182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-26-2010 01:55 PM
Can't open "session created on older version" - but it wasn't! BookSix Pro Tools TDM Systems (Mac) 9 02-04-2009 07:38 AM
