When extracting a stereo audio track from my commercially manufactured CD, for the purpose of having a 16-bit 44.1 kHz stereo .WAV file of the track,
- If I use iTunes software, with import settings set to .WAV encoder, 16-bit 44.1 stereo, I get one, stereo file... - If I import into a 16-bit 44.1 Pro Tools session, it will first convert into the left and right channel mono files for the session, and then I would need to bounce to a 16-bit 44.1 kHz stereo interleaved .WAV, to end up with that same, single, stereo file... Am I understanding these two methods correctly? And more importantly, what if any is the difference in the resulting stereo .WAV file? |
There should be no difference in the linear PCM data resulting in both files.
Pro Tools cannot work with interleaved files so must convert everything to dual-mono. If you want to bypass this step, just keep using iTunes. Personally, I use Exact Audio Copy in secure mode for ripping (PC only).
OK, thanks... so there would be no reason to think that the Pro Tools software would do a "better" job of extracting the linear PCM data correctly than the iTunes software...?
Right.
just drag the file from the cd to a location on your computer...
mac os x reads cd's as aif files. but if you really need a wav file for some reason then itunes is fine
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
I use Wavelab for ripping tracks from CD's. Wavelab7 runs on Mac now and they have a "lite" version for $99.
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
On a stereo audio track, the left track is completely dead | ckwhy2008 | Pro Tools M-Powered (Mac) | 1 | 04-09-2011 04:16 AM |
extracting vocal out of audio track? | bcntrble | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-13-2009 07:23 AM |
extracting a midi drum track into different parts? | tritonkorg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-22-2005 01:43 PM |
extracting tempo from imported CD track ... | john1192 | Pro Tools TDM Systems (Mac) | 1 | 10-26-2003 08:26 AM |
Extracting tempo from click track | thermal | Pro Tools TDM Systems (Mac) | 3 | 03-05-2002 08:28 PM |
