Old 07-31-2010, 05:22 PM
DJ Hellfire DJ Hellfire is offline
Question What's wrong with this laptop? Sandra & Video Included!
My boy has this laptop trying to run an original Mbox with Pro Tools 8.0, and it will not launch. Just gives an access violation error. Using all stock plugins and no extra toolkits. Just raw PT 8.0. Here is the video that shows the problem and the error. He has Vista, but I don't see that he has any service packs installed. Could that be it? The setup works on his W7 desktop!
http://s19.photobucket.com/albums/b1...oToolsfail.mp4
Computer
Model : Gateway M-6752
Workgroup : WORKGROUP
Host Name : ********
User : ********
Processor
Model : Intel(R) Core(TM)2 Duo CPU T5450 @ 1.66GHz
Speed : 1.66GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Mobile, Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Gateway
BIOS : Gateway 91.1E 01/10/2008
Bus(es) : ISA PCI PCIe IMB PCMCIA USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3GB DDR2 SO-DIMM
Chipset
Model : Intel Mobile PM965/GM965/GL960 Express Processor to DRAM Controller
Front Side Bus Speed : 4x 277MHz (1.1GHz)
Shared Memory : 8MB
Memory Bus Speed : 2x 554MHz (1.1GHz)
Memory Module(s)
Memory Module : Hynix (Hyundai) HYMP512S64EP8-Y5 1GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3)
Memory Module : Hynix (Hyundai) HYMP125S64CP8-Y5 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3)
Storage Devices
WDC WD2500BEVS-22UST0 (250GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache) : 233GB (C:) (D:) (H:)
Generic-Multi-Card (USB) : N/A (G:)
SanDisk Cruzer 8GB (USB) : 7GB (F:)
Optiarc DVD RW AD-7563A (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
SanDisk Cruzer (USB) : 96MB (J:)
Logical Storage Devices
RECOVERY (D:) : 11GB (NTFS) @ WDC WD2500BEVS-22UST0 (250GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache)
Hard Disk (C:) : 197GB (NTFS) @ WDC WD2500BEVS-22UST0 (250GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache)
New Volume (H:) : 24GB (NTFS) @ WDC WD2500BEVS-22UST0 (250GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache)
Optical Drive (E:) : N/A @ Optiarc DVD RW AD-7563A (ATAPI, DVD+-RW, CD-RW, 2MB Cache)
Removable Drive (G:) : N/A @ Generic-Multi-Card (USB)
U3 System (J:) : 7MB (CDFS) @ SanDisk Cruzer (USB)
Removable Drive (F:) : 7GB (FAT32) @ SanDisk Cruzer 8GB (USB)
Peripherals
LPC Hub Controller 1 : Gateway 2000 ICH8M-E (ICH8) LPC Interface Controller
Audio Device : Gateway 2000 82801H (ICH8) HD Audio Controller
Audio Codec : Sigmatel 76A0h
Audio Codec : Conexant 2C06h
Serial Port(s) : 1
Disk Controller : Gateway 2000 82801H (ICH8) Ultra ATA Storage Controllers
Disk Controller : Gateway 2000 Mobile SATA AHCI Controller
USB Controller 1 : Gateway 2000 82801H (ICH8) USB UHCI #4
USB Controller 2 : Gateway 2000 82801H (ICH8) USB UHCI #5
USB Controller 3 : Gateway 2000 82801H (ICH8) USB2 EHCI #2
USB Controller 4 : Gateway 2000 82801H (ICH8) USB UHCI #1
USB Controller 5 : Gateway 2000 82801H (ICH8) USB UHCI #2
USB Controller 6 : Gateway 2000 82801H (ICH8) USB UHCI #3
USB Controller 7 : Gateway 2000 82801H (ICH8) USB2 EHCI #1
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Peripherals
Media Player : ()
Media Player : SanDisk Cruzer (7.47GB)
Network Services
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 46%
Operating System
Windows System : Microsoft Windows Vista Home 6.00.6000
Platform Compliance : x86
Windows Experience Index
Current System : 1.0
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 07-31-2010, 05:28 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: What's wrong with this laptop? Sandra & Video Included!
Lots of stuff wrong. Only 1 hard drive. Must be a minimum of 2 hard drives. That hard drive is only 5400 RPM. must be a minimum of 7200.
I dont see a graphics adapter listed, so its probably integrated, also not approved.
Also no service pack for Vista, you need at least SP1, and its better with SP2.
Download them manually from the Microsoft website. Install SP1 first, then SP2.
Turn off UAC. Do the other Vista optimizations.
Install PT with Run as Admin (right click the setup icon, choose run as admin) Always launch Pro Tools with Run As Admin.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 07-31-2010, 05:32 PM
I know about the hard drive. He has a separate one. We are just trying to get it to at least launch. Also, it's a laptop, so the graphics will naturally be integrated. Thanks man!
Pro Tools 2021.12
Old 07-31-2010, 05:38 PM
Benoni's Avatar
Not to nit pick, but there are many laptops with separate graphics processors.
Here is the quote from Digidesign:
Pro Tools Windows Computers Require a Dedicated Graphics Controller.
Windows computers with integrated (i.e. northbridge-based) graphics controllers are not supported and may not perform well with Pro Tools. To achieve best results, the system must use a dedicated graphics controller.
For desktop computers this usually means a separate graphics card is installed. For laptop computers, this is usually an option offered at the time of purchase. Desktop computers that do not have a dedicated graphics controller installed will need to install either an AGP or PCIe based graphics controller. PCI or PCIx based graphics controllers are not supported.
Unfortunately, Windows desktop computers without either an available AGP graphics or PCIe graphics slot available, and Laptop computers without a built-in dedicated graphics controller cannot be upgraded to this functionality.
No harm, its a common belief that laptops only have integrated graphics, but its just not true.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 07-31-2010, 05:45 PM
Oh! Wow! I've only seen people use laptops with the built in graphics with Pro Tools. Thanks!
Pro Tools 2021.12
Old 07-31-2010, 05:49 PM
Benoni's Avatar
Its a common misconception. the graphics processor in a laptop resembles a CPU, not at all like the large card you put in a desktop.
Here is one you can see:
http://www.nvidia.com/object/product...x_260m_us.html
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 07-31-2010, 05:57 PM
Oh OK! I get it! I was thinking you were saying dudes were supposed to be carrying a monitor around with their laptops! LMAO!
Pro Tools 2021.12
Old 07-31-2010, 06:05 PM
Benoni's Avatar
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 07-31-2010, 06:11 PM
necjamc necjamc is offline
Out of curiosity, have you done the optimizations on the laptop. And have you turned off all powersaving stuff. I couldn't run PT on my Dell laptop (even just get it up and going) until I turned off the power saving stuff. My dell was set at 20% / 50% CPU from the factory. And it wouldn't even load up the program
Old 07-31-2010, 06:12 PM
Correct me if I am wrong but, original Mbox only works up to PT8.0.1 and Windows 7 wants 8.0.3(or 8.0.4)
Laptop Compatibility for Pro Tools SANDRA REPORT INCLUDED Richard621 Windows 4 04-01-2013 10:07 PM
Pt9.0.5 Help Please (Sandra Report Included) msuk Windows 2 09-25-2011 08:48 AM
Three problems since 8.0.4 - Sandra report included. David Sabine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-22-2010 10:44 AM
problems since 8.0.4 came to town 8^( sandra included wizayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 08-26-2010 10:07 AM
Help with a new system please (Sandra included) hootist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-27-2010 08:15 AM
