Old 07-07-2008, 11:09 AM
EarHole EarHole is offline
Default Stupid Latency on Sends
I just mixed an hour long program with all the sfx tracks routed to a track to print all the music, v/o and sfx as well as the mix at the same time.
Because of the latency on the sends the volume automation is delayed resulting in a loud burst at the head some of the sfx that were brought way down. Now I need to redo them.
Old 07-07-2008, 02:19 PM
espron espron is offline
Default Re: Stupid Latency on Sends
Just out of curiosity: why are you using sends to achieve this? Would it not be better to use multiple output paths to feed the various stem record inputs? I do this all the time and have never had the issues you are describing.
All the best
Espen
IMDB
Old 07-07-2008, 02:34 PM
TheHenchman TheHenchman is offline
All the best
Espen
Absolutely.
In fact the way I do it is senf the tracks to their respective stems, and the stems to the Final Mix, instead of double-bussing to stems and full-mix.
www.markhensley.tv
IMDB Credits
Old 07-07-2008, 04:38 PM
Well here's what I did...
I took all of the main outs of my SFX tracks and route the to an Aux track so I can control the over all level
with one fader. The main out directed to a bus "PrintMix".
Then I route a send out to a buss on the aux track as well that routes to a "PrintSFX" bus.
Then I created an Audio track with the Input directed to "PrintMix" (FullMix)
Then I created an Audio track with the Input directed to "PrintSFX" (SFX Stem)
I put both Audio tracks into record and print the Mix & Stem at the same time.
I don't normally do such long projects so I was trying to make it easy and do it all in one pass.
Old 07-07-2008, 04:47 PM
No, you've done it a bit backwards, IMO.
Create a SFX Aux and a SFX Stem Record.
Send all the SFX to the SFX Aux master, and the output of that Master to the input of the SFX Stem Record.
You do the same for Dialog and music.
Now, you send the output of all those Stems to the input of the Full-Mix record track.
Done.
www.markhensley.tv
IMDB Credits
Old 07-07-2008, 05:05 PM
Done.
Then how would I Limit the mix to ensure my final output doesn't push beyond a certain level.
Specs ask for -6db maximum.
Old 07-08-2008, 09:22 AM
Done.
Well, I put limiters on my main auxes, SFX, Dialog and Music.
But just as with the stem auxes, you can create a Master Mix aux that you don't touch, send all your Stem outs to that first, put an L1 on it, and send the output of THAT to the FullMix stem record track.
www.markhensley.tv
IMDB Credits
Old 07-08-2008, 09:35 AM
I'll give it a try but it sounds even more complicated then my way. Does DC adjust for all the delays of going through
the chain?
Let me see if I get this right:
Tracks routed to Stem aux, Aux routed to Print Stem audio Tracks,
Print Stem Audio Tracks routed to Mix Aux, Mix Aux routed to Print Mix Audio Track.
Old 07-08-2008, 10:13 AM
the chain?
Once you set up a mix template with that routing, you don't have to worry about it again.
And using auxe, as you now know, can result in nasty surprises.
www.markhensley.tv
IMDB Credits
Old 07-08-2008, 12:28 PM
Thanks for the advice... I'll try your way next time and see how that works.
HTML code is On
Sends in Low Latency Mode [Pro Tools LE] Nathanael81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-02-2010 08:06 AM
Sends Inactive w/ Low Latency Monitoring paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-30-2009 03:46 PM
Sends and latency copper ICON & C|24 1 07-07-2003 11:23 AM
Stupid question, what do you use sends for? saittam Digidesign Hardware & Software 3 02-17-2003 03:50 AM
output sends and low-latency montoring pkcraft 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-12-2002 02:35 PM
