nothing happens when I process with AudioSuite plugins, it only works when I choose "overwrite files".
I tried it in a new session, reinstalling pt, nothing helped, what can this be? I'm on 7.4 cs2 for a couple of weeks now and it didn't happen until now. |
"use in playlist" is on?
frank.
PTHDnPCIe 2025.6 (OSX15.5), Eucon 25.6, 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
![]() Quote:
but also with 7.4the overwrite won't show up on my puter until i stop playing as many of the old multi tasking abilities are out the window with 7.4 at this time it doesn't seem to handle while you are in play like it used to more than just the fade thing many people are hollering about
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Have you got "Pause during Playback" ticked in the task manager?
If so, try unticking that. Hope it helps, Timothy |
frank, thanks so much, "use in playlist" was off, I have never payed attention to that feature and I don't think it was ever on... but well... it works now!
what does that do? and why is there the option to turn it off if it won't process without overwriting? thanks a lot for the help and info! |
It processes just fine without that option on, it just doesn't place it back on the playlist when its done. Rather, the newly created region is in the region list and can be dragged out. Check there and your audio files folder and you'll probably find your attempts that didn't seem to be working.
AudioSuite: None | Madalyn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-02-2011 07:41 AM |
Vst to Audiosuite? | xes | Pro Tools M-Powered (Win) | 0 | 03-08-2007 10:37 PM |
audiosuite plug ins problem ...arrrggg audiosuite | hotcarl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-23-2004 02:35 PM |
Audiosuite Bug | trombino | Pro Tools TDM Systems (Mac) | 1 | 08-12-2002 06:31 PM |
Can't audiosuite | DESDRUMS | Tips & Tricks | 1 | 07-13-2002 12:44 AM |
