Old 07-24-2006, 03:34 AM
DaveSB DaveSB is offline
Default Which SATA 2 drive for G5 Dual Core
Im looking to buy a second drive for my new G5 2GHZ Dual Core to use as an audio drive and was wondering if the G5 SATA controller on the motherboard will run one of these SATA 2 drives
(I want of these three one because of the 16MB cache and they are priced just right)
Seagate: ST3320620AS
Seagate 320GB 7200 RPM SATA 3Gb/s 16MB cache Barracuda 7200.10
WESTERN DIGITAL: WD 7200rpm 320GB 16MB Int SATA 2 Carviar SE
WD3200KS
WESTERN DIGITAL: WD Single 7200rpm 320GB 16MB Int SATA2 Caviar Raid
WD3200YS
System will be a PT HD2 PCIe so Im wondering if something like this would be OK?
OR I have seen a number of PCIe SATA II cards so maybee I should get one of these and use in slot3 ?
thanks in advance
Dave
Old 07-24-2006, 04:40 AM
mix109 mix109 is offline
Default Re: Which SATA 2 drive for G5 Dual Core
You should check this
http://firmtek.com/seritek/seritek-2se2-e/
and this
http://firmtek.com/seritek/seritek-2en2/
I am usin the PCIX Firmteks on a G4 1.25 MIXCUBE System OS 9 and on a Dual G5 1.8 with HD2
Well built products with very good performance
Regarding drives i would prefer to stay away from Seagate,and go with the WD or Hittachi
Old 07-24-2006, 11:24 AM
zombie69 zombie69 is offline
and this
Why would you prefer to stay away from Seagate? Just curious.
I wear the pants. (My wife picks them out)
Old 07-24-2006, 01:37 PM
[/QUOTE]
My experience with ST SCSI's was quite bad in the past,but this month went over the limits, since i had 2 brand new SATA's failed the SMART test, and finally went urecognized and not accesible by the system under a 3 day testing,and the 3rd(IDE) one which i bought it 15 days ago,took it off the antistatic bag,placed it an enclosure,and the drive never worked(tried it on 2 more enclosures
with diff chipsets...and never worked RIP "__}
My 2c
Old 07-24-2006, 03:42 PM
minister's Avatar
minister minister is offline
FWIW ....
i have 12 SEAGATE CHEETAH drives ... NOT ONE has gone bad in 6 years....
Western Digital on the other hand ... 2 out of 3 went BAD! ...
YMMV
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
ProTools Boot drive migration to a new internal SATA drive audiowave Pro Tools TDM Systems (Mac) 1 05-03-2011 03:45 PM
G5 Dual 2.7GHZ - Sata I or Sata II Drive setting ? toneski Pro Tools TDM Systems (Mac) 4 05-06-2008 12:18 PM
AMD Dual Core Optimizer and WinXP SP2 Dual Core Hotfix PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-10-2007 08:29 AM
Second Internal Hard Drive For 2.0 Dual Core G5 Rambo66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-16-2007 09:06 AM
External Drive writing to Internal SATA Drive Teen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2007 07:29 AM
