Old 12-06-2005, 02:32 PM
mtung mtung is offline
Default Xmon and new firmware causing other problems??
I have received a new Xmon with the updated software that fixes the headphone dim talkback debacle, but there seems to be a problem with the monitoring in the main monitors. Mono doesn't work! Since this is my FIFTH Xmon, I would hope that the fault was somewhere in the wiring of the studio. So off I went to open up that Dsub connectors that connect the inpust and outputs of the Xmon and checked that they were all correct. They were. I also checked the I/O setup in ProTools, Everything is hunky dory, L/R comes out on 1 and 5. In ProTools, if I pan a track to the left, it comes out the left. If I pan right, it comes out of the right speaker. BUT NOW, pan a signal hard to one side and hit the MONO button. On my Dcommand, the signal stays hard panned and gets dimmed a couple db. The left side seems to dim a bit more than the right and the left side makes a click which i presume is a relay. I don't remember any cllicking before.
Can anyone else confirm this problem I'm experiencing? I really hope it's me doing something wrong.
Can anyone help?
Thanks
Mike
Old 12-08-2005, 01:19 AM
Default Re: Xmon and new firmware causing other problems??
Can anyone with the "updated" X-mon confirm that they do not or do have this mono issue?? Anyone?
Thanks
mike
Old 12-09-2005, 08:05 AM
Michael Coyle Michael Coyle is offline
My XMon which was factory replaced, not updated my me, does MONO the stereo buss. XMon formware is version 11.
MIchael
Chicago Recording Company - Studio 55
http://www.CRC55.com
Old 12-09-2005, 02:54 PM
Thanks!
It's probably my fault somewhere. I will check again that everything is correct.
mike
Old 12-12-2005, 10:42 AM
cjsorg cjsorg is offline
Just to further verify...I just double-checked our D-Command for the mono issue you described, but found no trouble with it.
-cj
Vibe56 Studio
www.vibe56.com
Old 12-12-2005, 12:25 PM
I found my fault in the wiring. No problem with the X-mon. It is fixed now and everything works. Whew...
I appreciate the help. Thanks!
mike
no firmware on XMON snkishore18 ICON & C|24 12 01-09-2024 01:37 AM
Digi 003 Midi Mode firmware upgrade causing problems DanielWiklander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-12-2012 03:24 PM
Firmware update on 003 causing MIDI timing problems???? gruntmaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-11-2009 12:10 AM
XMON Firmware Update Avid General 0 12-15-2005 08:15 PM
XMON Firmware Update Avid ICON & C|24 0 12-09-2005 10:51 PM
