Old 07-26-2005, 03:55 PM
JohnGreenham JohnGreenham is offline
Default Generating timecode
Hello,
I'm using PT 6.7 on a G5 Mac OSx 10.3.8. I've got a digital 192 I/O and a Sync I/O and I'm trying to get the Sync I/O to generate timecode so that I can slave another device with PT as master. I've followed the instructions in the manual which sound plausible until you get to the part that says "choose a clock reference..." The whole point of this is that the clock reference IS the Sync I/O. Either way I can't seem to get it to put out anything. Anyone have any ideas about this?
Thanks, JG
John Greenham
Direct Mastering Services
San Francisco, CA
Old 07-26-2005, 04:17 PM
Default Re: Generating timecode
In the session setup window, choose your clock reference. This would be video reference, video in, internal, AES/EBU, etc. Once that is done, go to the bottom of the session setup window and enable the checkbox marked Using SYNC (under generator). Then put Pro Tools online (Apple+J) and press play. You should see timecode advancing on the face of your SYNC I/O, in which case you just have to patch its SMPTE output to the slave device.
Old 07-26-2005, 04:25 PM
Richard Fairbanks Richard Fairbanks is offline
It is not totally intuitive, you have to put Pro Tools "online" as well as check the "generate timecode" (or whatever the exact text). To put PT online, on the transport bar press the button which is far left. Or use command-j.
Call me by my real name, "Postman"
Generating Timecode With LE patsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-10-2008 03:48 PM
Generating SMPTE Timecode in PT Adam Ings General Discussion 2 11-24-2007 02:25 PM
SSD generating timecode? [email protected] Tips & Tricks 1 09-01-2000 11:19 PM
USD and Generating Timecode Scotty Tips & Tricks 3 09-01-2000 03:35 PM
Generating Timecode from USD, Help hit productions Pro Tools TDM Systems (Mac) 2 06-04-2000 02:17 PM
