Old 07-13-2005, 09:07 PM
paronoff paronoff is offline
Default Setting up ADR Studio with a Control 24
Has anyone had any success using ADR Studio with a Control 24. If so any suggestions or web sites would be appreciated.
Paul
Old 07-28-2005, 07:03 AM
Jem1570 Jem1570 is offline
Default Re: Setting up ADR Studio with a Control 24
Do ADR studio's need tactile control of 24 channels at once? I'm asking not to be sarcastic but because I genuinely don't know. I would have thought a command 8 would be sufficient in an ADR studio.
Old 07-28-2005, 02:25 PM
trakbytes trakbytes is offline
The reason you would want a lot of faders for ADR is to instantly access multiple takes of an actor to comp the track together. Very often a director will want to hear, for example, "take five of the first half of the line and take seven of the second half". If you have several actors and are looping an entire scene, you can get a lot of tracks in a hurry, and having automatable mutes across a lot of faders can be a big help to put the track together. Often the ADR mixer will run a comp track of the various takes to give the editor an idea of the preferred assembly.
You could also record multiple takes on the same track and cut-and-paste the comp together, but generally you will not want to do that while the director and talent are still in the room.
You will need a pretty sophisticated talkback and muting system, since the director and usually the ADR supervisor are in the studio with the talent and will want to hear playbacks over the speakers. You will also want a listen-back system so the mixer can hear direction and keep the session running smoothly.
rcm
Save early and often! (or once a day whether you need to or not...)
Setting up a studio from scratch ChattyJ Post - Surround - Video 4 05-04-2006 11:38 AM
Setting up my studio gustavof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-23-2004 10:30 PM
Setting up a studio... Finchy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 11-23-2004 08:52 AM
help on setting up studio billy the kid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-10-2004 02:42 PM
just setting up my studio..help! brentm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-13-2003 11:27 PM
