Old 07-09-2002, 10:07 AM
bjorn for a reason bjorn for a reason is offline
Default performance question
I just bought a 001 and installed it in a biege g3 250.
I know its not officially supported but it works fine. I'm spoiled with tdm rigs at my studio but use this at home. I guess i was just hoping for more performance than i'm getting. 3 channel strips 1 reverb and this thing slows to a crawl. what kind of plug in count can you expect from a g4 833? [img]images/icons/smile.gif[/img]
Old 07-09-2002, 11:14 AM
Mightypudge Mightypudge is offline
Default Re: performance question
Short answer - more than what you're getting now. [img]images/icons/smile.gif[/img]
I guess that depends on the plugins. My G4 400MHz can do about 4 or 5 Waves 3.5 plugins before things get a little slow, so I would imagine a Quicksilver would do at least a few more comfortably.
Andrew
Old 07-09-2002, 11:39 AM
dreeam dreeam is offline
i run about 12 or 13 plugs and works fine
thats pushing it if i go for 14 boom error [img]images/icons/frown.gif[/img]
i have a g4 .wavs i gues 4 plugs and a like 5
cpu safe plugs but waves got the upgrade now that cuts the cpu useage [img]images/icons/wink.gif[/img]
Old 07-09-2002, 12:22 PM
Jerell Jerell is offline
if you upgrade your ram on the g3 youll get more plug in avalibility
Old 07-09-2002, 12:38 PM
where02190 where02190 is offline
FWIW, our G-4 dual 800 does 24+12 aux tracks in the Davec test. I would think the 833 would do about the same.
Old 07-11-2002, 10:00 AM
thanks for the replies. i've got 384 meg now
would more ram help?
Old 07-11-2002, 11:27 AM
SoundWrangler SoundWrangler is offline
More RAM definitely helps; 384 IMHO is pretty marginal for any current ver. of PT - at least knock it up to 512 or 640 & I think you (& your plug-ins) will be happier, espec. since RAM is so cheap now. Then assign more RAM (in Get Info) both to the DAE app (doesn't need a HUGE amount) & more importantly the PT app itself.
Old 07-11-2002, 11:34 AM
mixin'chick mixin'chick is offline
Sounds about right to me.
I would also add that you should run McDSP plugs for ALL eq needs and a % of you compression needs. It sounds as good/better than the WAVES stuff to me and many others and they are silly whe it come to efficiency.
My G4 466 can muster only 5-10 WAVES plugs depending on what they are.
And I have loaded for testing only 81 E4 McDSP Eqs and the session still ran fine and I was still able to engage 8 tracks.
It might help.
So would an Oasys card.
D
Performance Question. philip888 Pro Tools 9 1 11-05-2010 09:41 AM
Performance Question RobyM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-20-2006 02:31 PM
Performance Question Paul66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-01-2006 12:47 AM
P III, 800 mhz performance question.... Paul Curtiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-25-2003 01:40 AM
Performance % question... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-19-2002 07:04 AM
